LT waterpumps
Old Jun 25, 2008 | 07:36 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Default LT waterpumps
Why are LT waterpumps so bad, mine was replaced right before I bought it and no 40k miles later it is bad.
Old Jun 25, 2008 | 07:41 PM
Overboost's Avatar
Overboost
From: Flint Michigan, #2 in unemployment, #3 in Violent crimes
was it a rebuild? you can get a rebuild it it last but it better be a good one. otherwise a rebuild has been known to die in under 10,000 miles.
a nice delco factory replacement is the best way to go. a cheap knock off new pump is built with the same insufficient parts that a bottom of the barrel rebuild is going to have and thus have the same life expectancy.
Old Jun 25, 2008 | 10:10 PM
skybolt31's Avatar
skybolt31
I agree, the OEM is more money, but I think it is a better bet. Some rebuilds may last forever, but I think your odds are better with an OEM part. I don't always use OEM, but if the work involved is significant at all, I usually spring the extra money for the better part.
Old Jun 26, 2008 | 05:02 AM
James93LT1's Avatar
James93LT1
Veteran: National Guard
http://forums.corvetteforum.com/show...erpump+rebuild
Old Jun 26, 2008 | 09:00 AM
runner140*'s Avatar
runner140*
Mine lasted 130,000 miles.
Old Jun 26, 2008 | 11:01 AM
Randy93's Avatar
Randy93
St. Jude Donor '06
Lucky SOB.
I do not know what mine was, it was replaced before I bought the car, by the dealer.
Old Jun 26, 2008 | 05:04 PM
shop14's Avatar
shop14
120k on the oem before it went bad and 20k on the replacement so far.
Old Jun 26, 2008 | 05:06 PM
deerra's Avatar
deerra
I just installed a new Delco and my engine runs cooler temps than with the old one. I was doing a MSD so I went ahead and did the WP too.
Runs great.
Old Jun 26, 2008 | 07:37 PM
SAY WHEN's Avatar
SAY WHEN
I've had good luck with AC Delco ---poor luck with aftermarket remans---some dealers will offer a "cheaper water pump" (Reman)--in a attempt to be competive with the aftermarket for all the "bargain shoppers" out in the world that can't do the work themselves--ultimately-- and this is a unique saying---"YOU GET WHAT YOU PAY FOR."
To LT waterpumps
