Just a simple question regarding transmission
And if there is anything you feel worth mentioning from tips to possible problems let me know please.
Luckily, this topic has been explored substantially on this forum. Use the advanced search function, type in some parameter (i.e. "manual swap" or "auto to manual/stick"). Click C4 tech and performance and archives. Search. Here is what I found in 1 minute.
http://forums.corvetteforum.com/show...ht=manual+swap
The consensus is it is more cost effective and easier to sell your auto and buy a manual. However, it has been done before and IIRC, the only real problem was a chattering sound in reverse (IIRC) and the cost!. If you like the feel of stick and don't mind keeping the auto, rebuild it with a high stall Torque Convertor, Transgo Full Manual Shift Kit (like a manual without a clutch, it will not shift into the next gear until you shift it), and upgrade the transmission internals. (check out my thread - although I'm not doing the full manual option and forum member 'Sliding' has a new post on installing a new shifter and an old one on the actual stick conversion on his automatic).
Good luck with your decision/search,
Jonathan
