Header question??? Please Advise
Old Jun 27, 2008 | 09:31 AM
Gooseit's Avatar
Gooseit
Default Header question??? Please Advise
I have a 95 coupe, with corisa exhaust, open air lid with K&N filter. My question is,
1. how much performance increase will I get buy installing headers and hi-flow converters? (Can not remove converters in my state)
2. How hard will it be to install headers and converters on the LT1 engine?
3. Which headers are the best for the money
Thanks for your help.
Goose.
Old Jun 27, 2008 | 09:59 AM
pianoguy's Avatar
pianoguy
You'll probably only get 10-20 hp with a stock engine, but long tubes will benefit more if you do other engine mods down the road. I installed Stainless Works headers and Random Technology bullet cats on my LT4 - reasonably easy to install, and I got a great deal on a group purchase this spring. I hooked up mine to the stock cat-back, but they should hook up easily to your Corsas. Spark plugs are much easier to get at now, too. If you search, you can find several header install threads with detailed pictures.
Old Jun 27, 2008 | 11:54 AM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Most of the "higher-end" header companies make a good headers, I think every brand has a couple little
quirks..... I've got Hooker 02149's and they don't come with an alternator back bracket, and the oxy
sensor hole is on one tube instead of further down the collector where it can read 4 cylinders instead of
one....but other than those little issues, they are very nice!
Old Jun 27, 2008 | 12:08 PM
l88rocket's Avatar
l88rocket
Headers are very easy to install, and can be done with hand tools in a day, the cat's will need welded in, I like to make the cats unbolt with tabs.
Old Jun 27, 2008 | 06:04 PM
Merle@Exotic Muscle's Avatar
Merle@Exotic Muscle
Collections Ban
We make Headers and extension pipes to fit the Corsa exhaust with no cutting or welding you can merely just bolt everything up. Check out our GP thread as you can save $100.00 on a set of headers. Merle @EM 480-967-4222
Old Jun 27, 2008 | 06:19 PM
vetteracer92's Avatar
vetteracer92
I like the EM headers, the only hard part of the install was turning a motor mount bolt around for clearance. I drove mine on ramps and rotated them up from underneath. The finish on the headers are still excellent after 3 years so far.
Old Jun 27, 2008 | 07:07 PM
96vetteLT4's Avatar
96vetteLT4
Default Not worth it
Corvette Enthusist Magazine just did a install on the LT 1 and it only got them 9 h.p.. I've did the install on a 95 and 96 with the install not being that hard but again we only saw 10-11 h.p. gains on the dyno. I didn't put headers on my 96 LT 4 as I just didn't think that the end result of an average 10 h.p. was worth it. If you have a built motor than it might be better but for a basically stock motor I dont think the cost, leaks ect is worth it....G
Old Jun 27, 2008 | 08:15 PM
aboatguy's Avatar
aboatguy
I have a set of Earle's EM LTs on my car. I bought them here on a GP a few years ago. With the right gaskets you won't have header leaks and the Ceramic coating has been holding up well on my DAILY Driver.
The thing about headers is you don't need them, until you need them IE on a stock engine they won't help much but once you start working on the heads, new cam etc you will definately feel the difference. So I'd bet headers are worth 25-30 RWHP on my car now (check sig for mods), but when I installed them (stock engine) they cost me a little low end power and may have provided 10 rwhp on the top end.
So figure out what your plans are before spending the money on headers.
Mike
Old Jun 27, 2008 | 08:23 PM
TJM's Avatar
TJM
Goose.
Goose, headers just open a door. You gotta shove something else through it.
Headers are not magic, and other things need to be done to achieve the performance they would allow.
Timing and fuel, for one.
Stock injectors are at best ....not great.... The computer's stock engine management is "mild".
Think about a reprogram and a set of injectors as well.
Fuel pressure increases help. A K&N air filter will help too. .
With that done, the headers will allow the engine to maximize the modifications and you should see some results.
Old Jun 27, 2008 | 11:26 PM
Lichen's Avatar
Lichen
If Merle had kids, the money that I have spent there would have put them through Harvard. His headers are a work of art. With his longtubes, hi-flow cats, and a 3" B&B catback, I gained 20 rwhp. That was before cam, heads, etc. (Merle, how much you want for that C5? Marcus.)
To Header question??? Please Advise
