Failed Emissions Test Today...
On a bit of a different note, I got my 86 inspected yesterday at a local gas station and I was talking to the guy running the inspection. He mentioned a newer C6 that came in and wouldn't pass emissions. He said a lot of the older cars aren't passing either. Makes me wonder if it's the cars, the standards or the test equipment.
When he did mine, he let all the tests run at idle and never brought the car up to the RPMs the test was looking for. He seemed to know how to get around it.
Thanks for any help!
if it passes or you like the way the car runs. buy them. if not send them back and reinstall the multecs.
When I'm ready to change over to the Bosch III's I'm calling FIC
Vacuum leak.
Just like bczee, suncr, cevetteboy said.
It will cause rich too, tho' not constant, as the revs do their yo-yo thing. Rich, lean, rich, lean, ...
The computer reads air, feeds gas, burns. Some unread air is getting in on a vacuum leak, and it burns as a lean mix. O2 reads high, feeds some extra gas, and the revs come down, cause there's too much gas/not enough air. The rich condition varies as does the revs.
Ever tune the jets on a carb? Reduce the gas, and the revs increase up to a certain point. Increase the gas, and the revs go down.
The bad news is I decided to clean the MAF, IAC, and throttle body and put it back together and idle was high, getting a DTC 22 (tps low voltage). Seems the TPS decided to turn inside 90 deg. and will not mate up with the throttle plate. Anybody have this happen?, seems weird. I am trying to locate one ASAP but no one has one in stock. Oh well with some luck I should have one by Thurs.
I also wanted to thank Jon from FIC injectors. He saw my problem and took it by the horns and sent me some injectors to try no questions asked. Now thats proactive customer service. I don't know if it will get me passed the emmisions check but my car was definitely not running like it should and the computer was working like crazy to adjust the fuel mixture. I'll probably buy the injectors even if I don't pass yet as it was definitely part of the problem.
