Failed Emissions Test Today...
Old Jun 27, 2008 | 03:03 PM
miks139's Avatar
miks139
Default Failed Emissions Test Today...
Went for the test with a warm engine and failed the NO portion of the test.
#'s are:
HC 56.4 Limit of 117.0
CO 0.28 Limit of 0.65
NO 1195.1 Limit of 821.0
CO2 14%
My gas cap also failed but is an easy fix (new one).
The engine was hot and the temp here is about 85F.
No check engine lights on. Only issue is sometimes idle isn't steady (fluctuates between 600 and 1000) I plan on cleaning the throttle body and IAC valve this weekend to try to fix the idle problem.
Anyone know where to start?
Old Jun 27, 2008 | 03:20 PM
tomtom72's Avatar
tomtom72
St. Jude 15 Year Donor
Active Streak: 90 Days
St. Jude Donor '08 thru '26
Just a couple of thoughts......isn't NO the thing that the cat is supposed to clean up?
How are the O2 sensors, really old?
Did you check for vacuum leaks?
The fluctuation in the idle speed happens in closed loop or open loop or both?
Wish I could be more specific but I'm not really up to speed on these here computer cars...
Tom
Old Jun 27, 2008 | 03:25 PM
TJM's Avatar
TJM
I had a similar problem.
No steady RPM.
The A/C charge was low [real low] and the compressors was cycling on and of.
Turned off the A/C and breezed through?
TJM
Old Jun 27, 2008 | 04:05 PM
jimg's'93's Avatar
jimg's'93
O2 Sensors are relatively cheap, but that still wouldn't explain the fluctuating idle. I'd look at spark there. My LT was fluctuating then moved on to missing. Turned out I had 2 wires that were arching to the engine block. For you that would mean unburnt fuel.
Arching can be best checked in a dark garage. Just my 2 cents.
miks139's Avatar
miks139
No steady RPM.
TJM
Car was at operating temp 210F and a/c was off, by the time the test was done the operating temp was 230+, not enough air from their fan on the dyno!
Old Jun 27, 2008 | 04:09 PM
miks139's Avatar
miks139
I thought the IAC could cause this, it is a steady up for 3 seconds then back to normal for 3-4 seconds
Old Jun 27, 2008 | 05:18 PM
bczee's Avatar
bczee
Any Details on your vette, year, mileage, has maintance service been done. Get your engine scanned ODBI or ODBII scanner and not a code reader.
Things I always do before smog test:
Change the oil and filter.
PCV
Air Filter
Check and repair any vacuum leaks.
Tune up (plugs, cap, rotor, if needed).
Clean the MAF with MAF Cleaner spray.
Run a few tanks of good cleaning gas (Chevron or there bottle additives Techron is good).
Make sure the EGR and AIR system are working correctly.
Check and clean all of the electrical connections to the related equipement (MAF and its relays were key for me).
For the idle, I would suggest checking the IAC and TPS (get it on a scanner to diag the whole system) using FSM procedures.
Check and change any sensor, O2 is the most likely one to change after 80k or more. IAT can cause bad idle. (had some of these problems and swapped out many of the old sensors when I picked up my 88' this year, had many code, I got them al cleared).
Old Jun 27, 2008 | 06:39 PM
miks139's Avatar
miks139
PCV
Air Filter
I have a 1994 lt1. I just picked up the car a couple weeks ago. I have changed the oil, oil filter, and air filter but nothing else. The car has been running fantastic except for the recent idle problem when its warm. I will pick up a FSM. Are the Helms comparable?
I will also have it scanned and look into picking up a scanner for my OBDI system.
Old Jun 27, 2008 | 07:12 PM
SunCr's Avatar
SunCr
A/c is exempt from emissions certification (the EPA would like to include it) and if it wasn't, none of our cars would pass, so it should be off.
Fluctuating, surging idle, points to a vacuum, intake or exhaust leak which can make it lean and the ECM responds with too much fuel - only your fueling (HC's and CO) looks good. I'd confirm with a scan, but that high NOX, assuming fueling is ok, is either an EGR problem (if used) or a bad CAT. Scan it and see.
Old Jun 27, 2008 | 10:46 PM
miks139's Avatar
miks139
Thanks for the info SunCr. I guess Ill start with a scan next week
Old Jun 27, 2008 | 10:58 PM
kowalski340's Avatar
kowalski340
if my ABS and FX3 lights are on will my car fail it's smog test?
Old Jun 27, 2008 | 11:26 PM
CE_Vetteboy's Avatar
CE_Vetteboy
I understand your situation as I just went through the exact same issue. I thought the excessive engine temp caused excessive combustion temps which in turn caused the high NOx reading. However I was informed that the high engine (coolant) temp has nothing to do with high combustion temps (high combustion temps are related to high NOx). Ltx engines run most efficient at higher temps and thus will pass e-test easier at those higher temps. I would be more inclined to think you have a vac leak or ignition wire/spark plug issue. If the car is not throwing any codes, a scan is the best way to diagnose the problem. Does it smell rich at the tail pipes?
Old Jun 28, 2008 | 06:05 AM
miks139's Avatar
miks139
Doesn't smell rich to me. What did your NOx problem end up being? Will I be able to tell anything using the paper clip trick for codes or will I need to take it somewhere?
Old Jun 28, 2008 | 09:15 AM
NocarbutaVetteforme's Avatar
NocarbutaVetteforme
Granted your temps were up but did that come from driving the car down the road for about 30 minutes of warm up time? The reason I am saying this is that you need to get the cats hot. The wife thought she was doing me a favor one time by taking the car to get it inspected while I was at work. Well, she drove it straight over and sure enough the thing failed. I then drove it for about 30 minutes to get it the cats hot and sure enough it passed. If the O2 sensors have never been replaced then I would definite change them out. You will see an improvement in your fuel mileage as well as a side benefit.
Old Jun 28, 2008 | 10:01 AM
TJM's Avatar
TJM
I wonder what sort of Fuel Formula is in the tank?? weird science with additives and ethanol could produce who knows what, chemically?
Maybe a fresh tank of high grade fuel?
Old Jun 28, 2008 | 10:51 AM
miks139's Avatar
miks139
I drove the car for about 30-45 min. and took it to the highway and took it to a respectable speed. The more I think about it I am going to change out the o2 sensors as the car has 100,000 on it and I don't know when they were last changed. How many does a 1994 have? My FSM's are on their way but I do not have them yet.
Old Jun 28, 2008 | 10:54 AM
miks139's Avatar
miks139
Fuel is fresh. I found out the hard way my fuel gauge is not accurate.:o So....any old fuel is gone.
To Failed Emissions Test Today...
Old Jun 28, 2008 | 12:21 PM
YCarnut's Avatar
YCarnut
High NOx is the product of high combustion pressure/temperature. I would check the initial ignition timing and the EGR valve. If both are OK then I would suspect the converter(s), especially after a 100k miles. A
sticking EGR valve can also affect the idle.
Old Jun 28, 2008 | 05:36 PM
bczee's Avatar
bczee
The paper clip would only activate into the Diag mode in the computer and would flast the stored codes. You need to get a scanner to monitor the reading of the sensors that the ECM is getting input from. You can use a Digital Volt.Ohm meter by you would have to measure each sensor output one at a time.
I would change out the O2 and maybe the IAT. clean the Throttle body, IAC and MAF at a min...
Old Jun 28, 2008 | 05:44 PM
cjdietzman's Avatar
cjdietzman
Hey Mics, before you spend a lot of time and money...let me share my story.
I have had my 1990 C4 for about 8 months. At first, I failed emission in CT, in a similar manner to you. I ended up taking it to two other test centers to try and get it to pass. For the first two tests, I went in with a "hot" engine at normal operating temperature, after driving it for a while. I failed with high N.O.
For the third test, however, I went to an inspection station around the corner from my home, and only ran the car for a total of like 2 minutes before letting the guys run the test. The engine was still relatively "cold." I passed!!! You may want to try a retest with a "colder" engine.
*** I know that you may still have another problem to fix somewhere in the engine, BUT, this MAY get you through emissions while you try to fix it. Hope this helps. Good luck!
