94 LT1 Rough running
Old Jun 28, 2008 | 04:26 AM
ukpete's Avatar
ukpete
Default 94 LT1 Rough running
This old chestnut!!! just replaced all 3 oxygen sensors due to rough running/misfiring/stalling/ not restarting ...just been for a run (about 25mins) and its so much smoother so its nearly sorted but misfire on acceleration recurred on the way home.... car mileage is 50000, have fitted new hd battery, adjustable fuel regulator, fuel filter changed leads but not plugs yet....I dont think it is opti...people have mentioned egr valve/dirty mass air meter or ignition control module. ...any thoughts..
Old Jun 29, 2008 | 02:46 PM
ukpete's Avatar
ukpete
Changed plugs and fitted new fatter Taylor leads...running better but need to try car in traffic to be sure.......
Old Jul 7, 2008 | 01:55 PM
pcolt94's Avatar
pcolt94
Check the fuel pressure to make sure you are not running excessive fuel pressure. To much will make it run to rich.
Does the digital readout for the temperature sensor perform normal with expected temperatures?
A stuck open EGR would cause you some problems. Check it cold, see how it moves with your fingers.
I would also check the codes just to see if something shows up.
Old Jul 9, 2008 | 10:54 AM
ukpete's Avatar
ukpete
Thanks, will double check fuel pressure as fitted an adjustable fuel regulator last year. What pressure should I set it at? its std tune...
Old Jul 9, 2008 | 11:23 AM
pcolt94's Avatar
pcolt94
This is off the cuff so take it with a grain of salt. Idling should be about 38 – 42 psi. And when you rev it, it should go to about 40 – 45 psi. I think anything much above 45 would be out of line and excessive.
Old Jul 10, 2008 | 09:27 AM
C4happy's Avatar
C4happy
A leaking EGR will show up with a very bad Idle
Old Jul 10, 2008 | 10:37 AM
pcolt94's Avatar
pcolt94
A little more info just FYI.
Actually it could very well be the opti. Don’t discount it by any means, its definitely in the running.
However, hears a recent post with symptoms very similar to yours where it really sounded like classic opti symptoms but with a slight twist. Turned out to be the ICM which kind of surprised me but just another similar set of symptoms like an opti.
http://forums.corvetteforum.com/show....php?t=2070919
Sometimes you just have to make a decision and try a part to see what might work after you diagnose it to death. I changed the ICM chasing a problem once but did not fix it. But now I have an extra part so next time I can eliminate or replace that item quickly. It can be changed in no time at all.
Old Jul 23, 2008 | 06:24 PM
ukpete's Avatar
ukpete
Thanks for all your advice, still not completed my checks, will come back....
Old Jul 23, 2008 | 10:04 PM
cwyates4's Avatar
cwyates4
Is it only happening after reaching a certain temperature? Are you getting a check engine light?
A couple of people are having the same issue as you and have diagnosed it as the pcm, food for thought.
Here's a link to their thread:
http://forums.corvetteforum.com/show....php?t=2055839
To 94 LT1 Rough running
