Injectors
Old Jun 28, 2008 | 01:44 PM
vettaim's Avatar
vettaim
Default Injectors
I installed a set of 30 pound an hour injectors the I had 3 bad injectors so this is why I replaced them. The problem is it is running worse than before. It is idleing real high and when you take off from a stop it misses real bad and has about a 2 or 3 second flat spot. Any suggestions.
Old Jun 28, 2008 | 01:50 PM
STL94LT1's Avatar
STL94LT1
Did you reprogram for the larger injectors? If not, that is your problem.
Old Jun 28, 2008 | 02:00 PM
shop14's Avatar
shop14
too big an injector for the car, what came out of? 22lb or 24lb?
Old Jun 28, 2008 | 02:04 PM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
i looked at your profile. Why did you put 30lb injectors in that engine. First of all if you put the red top bosch in they are 32lbs in your car because they were rated at ford pressure not gm. your engine only needs 22lbs. so basically if you did not reprogram the ecu, you are putting in 80LBs of fuel per hour more.
32lb injectors will handle up to 410 of real CHP..
Old Jun 28, 2008 | 02:09 PM
StealthLT4's Avatar
StealthLT4
You should get some of the Bosch III's from FIC since you now need new injectors anyway. I just ordered some for my LT4 and can't wait!
Old Jun 28, 2008 | 02:12 PM
SAY WHEN's Avatar
SAY WHEN
Sounds like way to much for a basically stock engine (I read your profile)---You may be able to get around it by changing injector pulse width with a new tune/reprogram---but I feel you would be better off with a stock type injector.
Old Jun 28, 2008 | 02:38 PM
FICINJECTORS
Supporting Vendor
justin check your mail they were deliverd to your address at 10:28 today.. let me know..
Old Jun 28, 2008 | 04:25 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
WAAAAAY too much injector. Use no bigger than 24 lb.
Old Jun 28, 2008 | 05:14 PM
StealthLT4's Avatar
StealthLT4
Thanks! I live on a military base so I can't pick up on Saturday, but I'm looking forward to Monday morning!
To Injectors
