misc problems with 92
Old Jun 30, 2008 | 02:00 PM
shaneomac's Avatar
shaneomac
5th Gear
Default misc problems with 92
I just bought a 92 lt1 with an auto It drove fine for a week and just died no spark I towed it home and cleaned all the electrical connections and it started I drove it about 10 miles and it died again the next day I bought a new battery and a code scanner. The scanner showes codes 51 (prom)46 (fuel enable)63 (left o2 error)71 (AC evap temp sensor failed 68 AC relay shorted) 67 (AC pressor transducer degraded 66 (AC pressor transduceropen short) 65 (right o2 sensor rich. If I pull the codes off the speedo I get c12 module1 no codes for module 4 not even c12 no codes for module 9 not even c12
Itested for power at the ignition module and the ground at the module it was ok I dont have a fsm yet thanks Shane
Old Jun 30, 2008 | 02:40 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
That many trouble codes? I wonder if your ECM has gone ****-up? The 1992 models are notorious for ECM failure, and new replacement modules have been discontinued by GM.
You'll have to get a re-man or salvage yard part, just be sure to save your O.E.M. PROM chip.
Old Jun 30, 2008 | 02:47 PM
shaneomac's Avatar
shaneomac
5th Gear
Default more codes
I scanned it again and got 16 codes this time and no codes on spedo
Old Jun 30, 2008 | 03:09 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
What scanner?
I have a 93 and my ECM is the same as yours and they go bad more often than later models, but are not that bad.
What does the car do when it dies?
Is it like when you run out of gas, i.e. sputter or does it just cutoff?
The more info you give, the better help you will receive.
Old Jun 30, 2008 | 04:38 PM
shaneomac's Avatar
shaneomac
5th Gear
it runs great then the it starts to die it stall out like its running out of gas then it turns over real fast like no spark
Old Jun 30, 2008 | 04:40 PM
shaneomac's Avatar
shaneomac
5th Gear
the scanner i am using is an inova 3120 obd 1 and 2 scanner
Old Jun 30, 2008 | 08:26 PM
shaneomac's Avatar
shaneomac
5th Gear
just got back from driving it pulled same codes from scanner and pulled these codes from speedo module 1.1 code 41 ECM data comm lost.module 4.1 nothing module 9.1 code 64 TPS error code 72 serial data link error code73 spark retard monitor error thanks Shane
Old Jun 30, 2008 | 11:11 PM
SunCr's Avatar
SunCr
If you haven't, clear all the Codes and then restart, drive it, rescan.
To misc problems with 92
