Ac ???
Old Jul 1, 2008 | 09:05 PM
JD XIII's Avatar
JD XIII
5th Gear
Default Ac ???
My air is working well but it's only coming out from under the dash and a bit from the defroster. None is coming thru the dash vents.
Old Jul 1, 2008 | 09:30 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
What year?
Is it manual or electronic??????
You need to give all the details you can, so we can better help you.
Old Jul 1, 2008 | 10:15 PM
Da Mail Man's Avatar
Da Mail Man
scan through the tech section in the past 2-3 days and you will find very similar threads on this with a fix i am sure that will assist you....however, could be a broken vacuum line or bad/broken check valve at the drivers side rear valve cover area in the engine compartment......good luck.....
To Ac ???
