Underdrive pulleys?
Old Dec 25, 2001 | 05:36 PM
KYVette90's Avatar
KYVette90
Default Underdrive pulleys?
Anybody using underdrive pulleys on their crank? Did you notice any performance gains? Thanks in advance.
Old Dec 25, 2001 | 11:52 PM
KYVette90's Avatar
KYVette90
Default Re: Underdrive pulleys? (KYVette90)
TTT
Old Dec 26, 2001 | 12:13 AM
Mike92's Avatar
Mike92
Also, anyone use UD pulleys on an LT-1? Results?
Old Dec 26, 2001 | 12:44 AM
BobMachus's Avatar
BobMachus
Default Re: Underdrive pulleys? (Mike92)
Vic '89 seems to have documented some good results, there are others I don't remember who just now tho.
Old Dec 26, 2001 | 12:46 AM
Hawaii89vette's Avatar
Hawaii89vette
Default Re: Underdrive pulleys? (BobMachus)
I heard you can get a few horses from that, but you may run into problems with the alternator pulley not turning enough to recharge the battery.
-Tim
Old Dec 26, 2001 | 01:09 AM
Vic'89's Avatar
Vic'89
I have the underdrive crank pulley. I picked up some HP from it and have documented track times to back it up.
It should be good for a solid 1 tenth in ET.
The cons are the alternator will not fully charge the battary at an idle with the headlights on and the AC also on. Other than that , there seem to be no issues. As soon as you start to move, the battary will go above 13 volts.
Vic
Old Dec 26, 2001 | 03:40 AM
BlackRocket's Avatar
BlackRocket
I installed the underdrive pully's and felt a noticible gain in performance. The bottom crank pully is a little tough to get at and requires some patience. I used the March brand of pully's, one of the better known brands. My alternator survived for ten years this way and finally burned out. :lol:
Old Dec 26, 2001 | 03:44 AM
GlockLT4's Avatar
GlockLT4
Default Re: Underdrive pulleys? (BlackRocket)
:cool: I might think about doing that in the future.
Old Dec 26, 2001 | 08:11 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Underdrive pulleys? (Glock'94)
Sounds like I will have to get one while I have it ripped apart (documented in "The Project" post). Installing the balancer tomorrow. Sure would make it easier :cheers:
Old Dec 26, 2001 | 09:54 AM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
The mod is not worth the gain. :nonod:
Old Dec 26, 2001 | 01:38 PM
john25's Avatar
john25
Use the March Performance "Power and Amp" series pulleys. It's a three peice set, crank, H2O pump & alt pulleys. The alt pulley is made to compensate for the reduction at the crank. Your charging stays the way it should. And yes, you will notice a difference in sotp driving and it is a worthwhile change. :D
Old Dec 26, 2001 | 05:16 PM
Rynda's Avatar
Rynda
I've had one on mine for 5 or 6 years now. I picked up a couple miles per gallon, that has to translate into something. Never experienced P/S, AC, temps or charging problems. Well the volts do drop below 13 at idle, but who does much of that.
I have a friend who likes to backpack, his philosophy when filling his pack for a hike is, "Take care of the ounces and the pounds will take care of themselves." I think that that notion applies to hot rodding as well. Not every improvement will give you 20 horsepower. To catagorically relegate a small increase to waste of time is counter productive. Spending a $1000 for 1/100th of a second would be dumb (for the street) but $100 bucks or so for ~ 1/10th of a second here and there; absolutely.
I think that my crank pully was a wise investment :)
Old Dec 27, 2001 | 01:32 AM
BowTieBlood's Avatar
BowTieBlood
Default Re: Underdrive pulleys? (Rynda)
I've heard of people using pulleys with both good and bad out comes...
A while back there was a post about LT1/LT4 pulleys, I think it was basically decided from those who DID post in that, that pulleys were not worth the money. I've opted not to get pulleys when I start buying parts for my car. :seeya
As you can see though some people gain, I've never had any myself, good luck.
To Underdrive pulleys?
