86 vette bumpers
Old Jul 3, 2008 | 02:06 PM
PMARTINEZ92126's Avatar
PMARTINEZ92126
Default 86 vette bumpers
im trying to take off the thin black moulding on the front and rear bumpers so that i can paint the bumpers with the moulding off. Im having a problem with the tiny bolts attached to the moulding that keep turning when im trying to remove the attached nut to remove the moulding. Is there a way to remove the nut without having to go at it with a dremel cut off tool. I having trouble with about 4 nuts not wanting to come off.
Old Jul 3, 2008 | 02:26 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Spray some PB Blaster on them and let them sit over night. Then try again.
Old Jul 3, 2008 | 03:40 PM
PMARTINEZ92126
i put a ton of wD-40 on them but i guess my problem is that the bolt that attaches the nut turns freely. I guess the bolt from the moulding came loose so when i turn the nut the bolt moves to. Its move very freely so im thinking i may have to go at it with a dremel cut off tool.
Old Jul 3, 2008 | 03:57 PM
3D-Aircrew's Avatar
3D-Aircrew
Default Why not just mask off the bumper to paint?
I'd be afraid that the strip would never look the same after so much wrangling to get it off.
I agree that taking it off would yield a better job but if you have to cut it off then I'd make sure you have a replacement for it in the pipeline.
Old Jul 3, 2008 | 05:11 PM
PMARTINEZ92126
i used a little dremel to take 3 of them off and it seemed to work fine, although, it took awhile. One thing I did that was a mistake was use a large grinder to take the metal off the nut and bolt faster. I was going to go with the little dremel afterwards to cleanly take it off. The big Milwaukee grinder took off the metal quickly but it also heated up the bolt to the point where it started to melt the urethane bumper. Stick with the little Dremel and only grind a few minutes at a time allowing it too cool before doing it again.
Old Jul 3, 2008 | 09:19 PM
Bob CTS's Avatar
Bob CTS
Had to do the same on my 86. I eneded up replacing the belt strip and had to compormise on the nuts the OE are very expensive.
To 86 vette bumpers
