HELP. Need LT1 Identified
Old Jul 3, 2008 | 07:50 PM
Iskenderian's Avatar
Iskenderian
Default HELP. Need LT1 Identified
Hello all,
Greetings from the C3 tent. I need some help identifying what year this LT1 is. I bought it from a yard that said it was from a 1994 Impala SS. But the crankshaft appears to have a key way. (which seems to suggest 96.) I am trying to figure out what year it is to buy the proper balancer hub. Thank you again in advance
Bob
Old Jul 3, 2008 | 07:55 PM
rklessdriver's Avatar
rklessdriver
It dosen't have the crank sensor in the front cover (for OBDII) but it does have the big hole for a pin drive Optispark so its a 95 or 94.
All LTX cranks have the keyway slot on the crank nose. They just don't use it.
Will
Old Jul 3, 2008 | 08:00 PM
Iskenderian
Will
Thank you, I must have been sent the wrong part then.
Here is the hub that(I was told) was for a 95 Corvette. (with bolts) the one without bolts came off the Impala Donor engine. LTx Vetts and Camaro's should have a 3.5 inch hub If im not mistaken. They sure look the same to me. Cranks are the same for all 92-95 LTx's?
Jegs has the correct size for a 92-95 Corvette. Maybe I gotta buy new.
http://www.jegs.com/i/JEGS/555/51607/10002/-1
thanks again
Bob
Old Jul 4, 2008 | 03:17 AM
rklessdriver
You need to buy the hub and pulley for what ever accy drive you are using. There are 3 different accy drives.
1)F body
2)Y body
3)B body
There are 6 different length LTX balancer/pulley hubs.
1)93-95 F body
2)92-95 Y body
3) 94-95 B body
4) 96-97 F body
5) 96 Y body
6) 96 B body
On the hubs anything after 96 is going to be .100 shorter because the OBDII motors had a reluctor ring for the crank sensor in between timing gear and balancer/pulley hub.
Looking at your pics judging by the location of the tensioner, it appears you have a Y body (Corvette) accy drive and a B Body (Caprice) balancer hub.
Will
Old Jul 4, 2008 | 03:21 AM
LT1 Spirit's Avatar
LT1 Spirit
thanks again
Bob
Im I right to say that the hub he has and the one from jegs is the same (3.5)?
Old Jul 4, 2008 | 10:01 AM
Iskenderian
Will
I think your right. The hub I was sent appears to be identical to the hub i took off the Impala Lt1. So I need the 92-95 Corvette Hub and I should be good to go.
Bob
To HELP. Need LT1 Identified
