Courtsey light problem
Old Jul 4, 2008 | 10:58 AM
ps374's Avatar
ps374
Default Courtsey light problem
The other day I noticed my courtesy lights did not go on when the D/S door was opened. However the passenger side worked. So I figure a bulb or a bad door switch. Today the passenger side does not light neither the door or the light under the dash. However the lights behind the seat work when you open the hatch. The lights in the door and under the dash do not work. I understand the horn ,radio antenna are all on the same circuit as the courtesy lights. These items all work??? Were should I start.
Old Jul 4, 2008 | 11:17 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
From my 86 FSM, but still helpful.
http://members.shaw.ca/agent86/Interior%20Lights.pdf
Old Jul 4, 2008 | 11:50 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Could be a faulty courtesy light delay module.
To Courtsey light problem
