Will these shocks give a better ride on the C4. When I go over big bumps I have to check the fillings in my teeth. I have Monroe sensitracs on now , better , but not good. Thanks in advance, Jim.
Shocks won't really change the ride quality; that's the spring's job. That being said, 87's had some pretty stiff springs. Unfortunately, you can't simply switch to later-C4 springs as they changed design in 88, but you could get softer springs from VB&P or some such place.
I do have QA1s and love them, but they won't really help with a harsh ride.
I tried springs from VB&P and it is actually worse as far as getting a harsh ride. I told them the kind of ride and handling I wanted, got the springs they recommended along with Koni adjustable shocks. I think the only way around the harsh ride may be coil overs, I'll try this route sometime, now the car is painful to drive.
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
What do you have your Koni's set at? What springs?
QA1 shocks are, IMHO, terrible. I had a set on my C5 and they blew out THREE TIMES in a year. Additionally, ride control was terrible compared to my Koni's- I'm surprised you're having trouble with them.
If you decide to sell the springs, let me know...
I'll have to check and see what kind of springs they are, I got them about a year ago. I will end up selling them but I'd have to install coil overs first, it might be a while with all the projects I have lined up now.
