85 Cold start injector
Old Jul 5, 2008 | 12:23 AM
js292's Avatar
js292
Default 85 Cold start injector
Well it looks like I lost my csi. I did a search and saw several old post about deleting it. Is it still something that is practical or feasible?
This is what happens when you sit on your butt for two years after you drop your motor in and can't remember where you put your stuff.
Old Jul 5, 2008 | 01:11 AM
rodj's Avatar
rodj
The '89 and later L98's that had it deleted had a revised program to give extra fuel during cold starts.
I deleted mine and before I reprogrammed the chip had no starting problems given low temp here is 60.
Only problem for you is you need the plug ( from TPiS ?) to fill the hole in the runner left by missing CSI as well as a cap for the end of the fuel rail.
Old Jul 5, 2008 | 01:28 AM
John A. Marker's Avatar
John A. Marker
Plug hole unless your intake has it deleted and plug the rear fuel rail on drivers side.
You can operate without it. The car may crank a little longer, but it will start without it. The SuperRam does not have it, so all of us with the SR make due without it. My computer chip doesn't have any allowance for this being removed.
Old Jul 5, 2008 | 02:09 AM
Kool88vette's Avatar
Kool88vette
I threw mine away about 3 years ago. I never had a problem but I don't live in a cold area.
Old Jul 5, 2008 | 08:16 AM
JackDidley's Avatar
JackDidley
We get single digit weather here and I went 3 years without it. Just cranks a bit before starting. In Texas you will not miss it.
Old Jul 5, 2008 | 11:00 AM
js292's Avatar
js292
thanks, I won't worry about it then.
Old Jul 5, 2008 | 12:24 PM
Demonic85's Avatar
Demonic85
The car will still run just fine without it. When it gets colder out it will be harder to start though. You could also upgrade the computer to a '89 but you'll have to change some wiring and plug the hole.
To 85 Cold start injector
