Winter trickle charge?.?.?.?.?.?
Old Dec 26, 2001 | 03:53 PM
Bartman's Avatar
Bartman
Default Winter trickle charge?.?.?.?.?.?
Just a simple question.... Can I trickle charge (2 amp) my '96 with the battery cables still hooked to the car. Is there a possibility of damaging the computer or something? Anything I should know? Just a little paranoid that's all. Thanks
Bart
Old Dec 26, 2001 | 04:11 PM
jfb's Avatar
jfb
Default Re: Winter trickle charge?.?.?.?.?.? (Bartman)
You can trickle charge with the battery cables connected safely. The trickle charger should taper its charge (not 1 or 2 amps continuously) or the acid level will drop and distilled water will have to be added periodically. You can use a timer on your charger set for its minimum duration (usually 15 mins) each day . Don't leave the battery sitting for long periods because the plates sulfate and you will have to replace the battery in the Spring.
Old Dec 26, 2001 | 07:32 PM
djpearn's Avatar
djpearn
Why not just buy a battery Maintainer from Wally Mart. Mine works great. It's a 1.5 amp slow charge that shuts off/on automatically and is small enough to mount in permanently beside the battery. You dont have to disconnect the battery from the car and it wont boil the electrolyte away. They use them in boats to keep the batt at peak charge all the time.
Old Dec 26, 2001 | 10:50 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Winter trickle charge?.?.?.?.?.? (djpearn)
Why not just drive it???
Old Dec 26, 2001 | 11:00 PM
Bartman's Avatar
Bartman
Default Re: Winter trickle charge?.?.?.?.?.? (Mr Mojo)
I wish Mr. Mojo!! why? cause of a couple feet of snow............ Sometimes western NY sucks. I do like to ski, but nothin's like drivin the vette. :D
Old Dec 26, 2001 | 11:03 PM
Dennis McDougle's Avatar
Dennis McDougle
I use a battery tender works great.
Old Dec 26, 2001 | 11:13 PM
Mr Mojo's Avatar
Mr Mojo
Gotcha Bart!
Old Dec 27, 2001 | 09:51 AM
Bartman's Avatar
Bartman
Thanks for the replies. I will have to go get one of those battery maintainers from wally-world.(Walmart is a wonderful place). Have a good day and pray for SPRING..... :D
To Winter trickle charge?.?.?.?.?.?
