High Beam switch.
Old Dec 27, 2001 | 08:11 AM
oceanaire's Avatar
oceanaire
Default High Beam switch.
HI. New to the C4 section. Just got a 95 Black/Black Coupe with 32,000 miles. Not a perfect car, but really sharp. This is my 1st C4. Anyhow I assume the high beam switch is on the turn signal arm on the left side of the steering wheel. Well, when I pull back, nothing happens. It comes back fine, but no click, and no high beams. How hard to replace this switch, and has anybody done this. Thanks, Eric
Old Dec 27, 2001 | 10:21 AM
JonM's Avatar
JonM
Default Re: High Beam switch. (oceanaire)
You need to remove the steering wheel. First take off the horn button and the plastic backer plate. Then remove the two screws holding the telescopic lever in place. You will need a steering wheel removal tool (you can borrow it from Auto Zone) then it’s just a matter of taking out the two screws holding the turn signal lever and uncoupling the wires. Here are a few pics. http://www.aros.net/~rbuck/column/tiltcol.html
And a more in depth explanation
http://www.gnttype.org/techarea/susp..._steering.html
Old Dec 27, 2001 | 10:34 AM
oceanaire's Avatar
oceanaire
Default Re: High Beam switch. (JonM)
Thanks Jon. :cheers: :) Eric
To High Beam switch.
