So, you are not disconnecting the IAC at all....just getting the engine warm to go into closed loop and then turning the adjusting screw on the TB and checking the count.
Yes, timing is correct. I took off the IAC off the TB this weekend. All passages are clean...like new aluminum and pintle is set at 1-1/8"(just a hair less) and checked the resistance on the IAC electrical....all in specification.
This is a completely different way of setting the idle than "by the book", but with the real time data count this might do it. Always looking at different approaches. Thanks -John
Correct.
Did you take the IAC housing off and clean it too?
This is a method taught to me by Brian Ebert of Hightechmotorsport. So far, it has worked on my 74219 cam with the Superram and my new cam.
IAC housing was perfectly clean when I pulled it off last weekend. Not any sign of carbon or any other deposits. Pulled the IAC out and tested the resistance and checked the distance on the pintle. All passages good.
I will try your method soon.....105 out side currently and just finished up 12+ hr day. I will wait until it is cooler.....WINTER
Ive got an 86' with an intermintant idle problem ,it will run great then sometimes it will idle up to about 1200 rpm's when I come to a stop.then when I go to take off again it will drop down to 700 rpm's like it is suppose to.any suggestions?
You probably have at least one vacuum leak. Vacuum leak will make a lawnmower lope idle.
Crank up the idle to get steady rpms (it has to be steady). Spray some starter fluid ALL around the intake, and wait for increased revs. EVERYWHERE that vacuum gets routed, you have to check. Like a water hose in reverse - every fork in the hose can have its own leak downstream. Same with vacuum.
You only need to block off all unnecessary hoses for that. In my car, that means the vacuum line and the brake booster. If it changes when you reconnect it, there is your problem and go chase that line.
I used a "C" clamp to close off the brake booster vacuum line....no change. I used a vacuum gauge hooked into a "T" fitting and connected to every vacuum line that was running off the plenum and other sources...all showed 15 inches of vacuum...except the small line to the air diverters which showed 8 inches. These valves send air to the exhaust manifold or to the cat. I sprayed carb cleaner around intake and all runners on the SR to the degree that I had cleaner RUNNING off the back of the block.....NO change in rpms. When in open look, idle is fairly steady, once in closed loop it swings. I just don't see a vacuum leak anywhere.
I am taking off for a few days to spend with the kids and grandchildren, will tackle this upon return. I am thinking that aklim's suggested adjustment might do the trick. Will let you know.
Yes, I believe it is a seperate system, but it still draws vacuum.
Draws vacuum from what? It is an air pump. Solenoid comes on, it injects air into the exhaust manifold and/or catalytic converter. I don't remember taking a vacuum line off.
I thought that the AIR valve is a one way to the exhaust manifold and the air pump feeds the diverter valve which is governed electrically? At least that was how it was done on my 91 Firebird and when I transplanted the motor, I took it all off.
I must admit that you are right from the diagram. It has been so many years since mine "fell off" that I must have forgotten. Either that or since 93 when I had my superram on, I must have forgotten to put in the vacuum. Guess we learn something everyday or have someone knock back what we forgot.
Maybe he needs to take the line off and just route it to the FPR and forget about the AIR system for a bit and see if it works? If so, it might be the AIR system that is leaking.
