Bad FPR verification
Old Jul 9, 2008 | 10:35 PM
billvh's Avatar
billvh
Well, now I'm confused. I went out in the garage last night, and the pressure guage had 23 lbs. Turned on the key, pressure rose and held, did it again, it dropped to 0. Today I tried to get it to hold by pinching gas lines, couldn't get it to hold pressure, then again it held on its own a few times. Couldn't get it to drop by pecking on FPR. Now I don't know if it's the FPR, or the check valve in pump (sounds like the most likley culprit). I hate to just start replacing parts.If its the valve, would an inline valve work?
P.S. I also have a worn throttle body and am looking for a replacement. (not related to this problem)
Old Jul 10, 2008 | 09:54 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Is the bleed off causing any starting/running problems ?? I wouldn't bother trying to put an inline check valve in. My 86 had a leaky pulsator and would loose all pressure in a few minutes. This caused me no starting/running issues. I replaced it with a piece of injection fuel line and 2 clamps and pressure loss was fixed.
Where are you clamping the fuel lines and what are you using ??
Old Jul 10, 2008 | 04:24 PM
billvh's Avatar
billvh
I'm just using vicegrips, I might just not be closing the line off completely. I'll mess with it this evening. It cranks a little too long before it starts is all. It's fine when running
Old Jul 10, 2008 | 05:25 PM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
go get a wood mixing stick and break off 2 pieces a inch long.. Put a piece on each side of the hose, then use the vice grip or a c-clamp.. You can damage the hose easily clamping on the rubber plus you can really seal it off better this way,
Old Jul 10, 2008 | 11:31 PM
AGENT 86's Avatar
AGENT 86
Another good method is to cut some copper pipe(or similar) and slip it over the jaws of your vise grips. I have needle nose vise grips that work well with 1/2" copper pipe.
http://members.shaw.ca/corvette86/Fu...mDiagnosis.pdf
