high coolant temp
Old Jul 8, 2008 | 06:59 PM
rolando4812's Avatar
rolando4812
Default high coolant temp
this answer may be right under my nose. but i just wanted to get some suggestions. the temp on the gauge reads 230 within the first five minutes of driving. they even reached 250 for a while and went back down until they rose steadily back to 230 before i came into work. is this a fan problem? i put some coolant in it yesterday because it was doing the same thing.
Old Jul 8, 2008 | 07:13 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
suggest starting simple.
check for debris in front of AC Condensor (the thing in front of the radiator). Lay under the front of the car and look up just before the plastic air dam.
check for debris in between the AC condensor and radiator.
Check to see if at least one fan is coming on at the 230 temp.
try turning on the AC, do the fans come on then?
Advise the above results and we'll try and help.
Old Jul 8, 2008 | 07:14 PM
89er's Avatar
89er
Sounds like a stuck thermostat.
Old Jul 8, 2008 | 11:42 PM
89 Bob L's Avatar
89 Bob L
Check the following; Start the car and turn the a/c on. Are the fans on? Check the following, not in any particular order:
Check the air intake for debris as theadmiral94 noted along with his other suggestions.
check the fan relays
Old Jul 9, 2008 | 04:53 AM
94bluedevil's Avatar
94bluedevil
When my 94 LT-1 was overheating, it was due to the fans not coming on. The fan temp switch...(i think thats what its called) which ever switch is read digitally it was reading very low, and the engine temp was high so it never told the fans to come on.
That fixed it but still in traffic or long periods of idling my temp will reach about 230... IS THIS NORMAL?????
Old Jul 9, 2008 | 08:31 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Yes, that is normal for sitting in traffic.
Check out this thread for some of the reasons these cars run hotter than most people are used to seeing:
http://forums.corvetteforum.com/show....php?t=2072211
And vader86 said it best:
Originally Posted by vader86
Every other car you own has a grill in the front to suck air through, the C4 does not. They are bottom fed, and their cooling air is hot off the pavement. There is no way for the temperature to stay down unless the thing is moving at speed. At idle, they will all go to their fan temperature setting no matter where it is and no matter what the stat is set at, if left alone long enough, assuming its not frigid outside.
In short, its an airflow/packaging problem.
Old Jul 10, 2008 | 12:59 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default temp
think about it, it sounds like a combo of things.
low coolant, bad thermostat, lean running, bad temp gauge sensor, trash in front of the radiator, pastic bag sucked up in the intake tract, etc.
Also sounds like the engine needs burping
To high coolant temp
