Problem with Vacuum Air Diverter Valve
Old Jul 9, 2008 | 03:05 PM
iroc-n-roll's Avatar
iroc-n-roll
3rd Gear
Default Problem with Vacuum Air Diverter Valve
I have a 1985 C4 and I'm trying to determine which part or parts that I need to replace in order to fix my problem with the heat+A/C air diverter. The air volume from the blower motor diverts to the proper vents at low RPM. Once I accelerate and bring the RPM and vacuum up all the air moves to the windshield area or defrost. I called chevrolet and all the parts have been discontinued for this problem. GM part #'s 1996717-Defrost Vacuum Valve Actuator, 1996718-Diverter Valve acuator, 1996719-Valve Front & 1996720-Valve Rear. Also they listed a Heat + A/C check Valve. Does anyone know exactly which part or parts I need and where can I get them? Also in manual pics of this would be great. Thanks... Mike
Old Jul 9, 2008 | 03:19 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
The check valve may be toast. Follow the vacuum line from plenum to the back of the intake base and you will find the check valve/tee.
Old Jul 9, 2008 | 03:20 PM
SunCr's Avatar
SunCr
Check hoses at and the Vacuum Tank in the left head light well. The tank should hold 10 ins. if you suck it down with a tester. It's there to supply vacuum under the conditions you describe - none of the other stuff should have anything to do with it.
Old Jul 9, 2008 | 04:07 PM
iroc-n-roll
3rd Gear
Thanks, It may very well be the vacuum tank in the driver's side headlight area. I just got a C4 and this is my first Corvette and I don't have a clue about parts that are unique to the Vetts. My step son hit a deer about a month ago and it completely ripped out the headlight assembly. I've since replaced the headlight assembly, motor and never thought to check for any other broken parts like vacuum tanks or other canisters. I'll try this first. Thanks for you quick replies. I have three f-Body 3rd Gen Camaros and bring a lot of knowledge on L98 & TPI parts, just
Old Jul 9, 2008 | 06:44 PM
Da Mail Man's Avatar
Da Mail Man
Old Jul 10, 2008 | 08:28 PM
SunCr's Avatar
SunCr
All cars have vacuum tanks - well except maybe a Yugo since there's no a/c or cruise. The Vette sticks it in the headlight well - trucks are usually on the rear of the hood - the F and G Bodys sometimes hide them below the front of the left/right fender.
Old Jul 17, 2008 | 09:37 PM
CELT4Ragtop's Avatar
CELT4Ragtop
Default Similar Prob
I think I have a similar problem. When I turn on the A/C (i.e. everyday all day down here in FLA.) The A/C only blows out the Defrost vent and fogs up the windshield (outside.) Nothing blows out the other vents. Does anyone know if there are any instructions (maybe with a photo or two) for the wrench impaired. I have a feeling it is the vacuum and I'd like to check it out, but I'm not sure what to look for.
To Problem with Vacuum Air Diverter Valve
