LT1 IAC part numbers
Old Jul 11, 2008 | 02:29 AM
Elementaltoad's Avatar
Elementaltoad
Default LT1 IAC part numbers
It appears that not all LT1 IACs are the same. I tried a Borg Warner 21755 tonight and the tabs around the bolt holes were too large causing the new IAC to sit crooked. I ended up having a High idle issue due to the pintle jamming in the throttle body.
Is there a preferable IAC for a 1995, the original is a borg warner 21965 (or at least that's what was in there). Looking closely reveals that the tabs on it are just a hair smaller.
Is there a difference between a LT4 IAC and a LT1 IAC? I'm not understanding the variance. I'll try to get some pics for you guys tomorow.
Old Jul 11, 2008 | 03:11 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
BWD & Niehoff 29165, Standard AC125 and AC27 Hopefully the link will work. If not, add vehicle and look them up. Easy Money
www.partsamerica.com
http://www.partsamerica.com/ProductL...e+Control+Unit
And Shobox's masterlist
http://shbox.com/1/Parts.htm
Old Jul 11, 2008 | 01:06 PM
Elementaltoad
Aparently the 21755 is for a LT5, and i have an LT1....Too bad i broke the part on install I paid 60 bucks for :o
Old Jul 11, 2008 | 10:38 PM
steve40th's Avatar
steve40th
Ouch. The LT1/LT4 are the same for 96, and 95 LT1 had the same. I am not sure of 94s. But 93 and olders have been around for a while.
Old Jul 13, 2008 | 02:51 AM
Elementaltoad
Bought a IAC from autozone by the part number #AC139, which worked perfect. Turns out the 21755 that I broke has a wider neck and will sit crooked in the IAC port, I have no clue why they offer the 2 differing parts.
A replacement part for the original part number of 17113188 seems to fit the LT1s. Definitely cured my rough idle and sluggish start issues as well as stopping the A/C from "dragging" down the motor at a stop or cruise.
Thanks for the help Steve!
Old Jul 13, 2008 | 04:10 AM
steve40th's Avatar
steve40th
Glad I could help.
Old Jul 13, 2008 | 05:42 AM
Weav's Vet's Avatar
Weav's Vet
Thanks for posting this. I've been having the same type AC issues.
To LT1 IAC part numbers
