Brass plug on power steering rack
He says the power steering rack is leaking from a brass plug on the bottom of the rack. He drove the car a few feet up the curb so I could look under. It made a moaning sound because all the fluid has leaked out.
I saw the plug but it was not dripping, but that could be because there is no fluid left. It was moist at the bottom of the rack. I cleaned off the plug area and took a picture. I was on my back looking up at the rack for the picture.
The plug is almost flush with the rack. It has no allen or hex fitting that would permit you to tighten it.
What is the purpose of the plug? Can it leak? If it can leak then what is the fix short of replacing the rack? Thanks.
I sent Herb, the owner, the response. Here is his response:
"I did some searching and found a bunch of warnings 'be careful not to break the plastic cover in the middle...',
but they don't say what the plastic cover is for. It may be a cover for the brass piece of which you speak.
If it is, can it be replaced?"
End of Herb's message.
I was under the car only long enough to wipe off the brass pin thing area with a rag and take a picture. Now that I look at the picture again I see a black something where the pin is. I assumed the rack was black aluminum in that area, but it may be a black plastic cover.
Herb is a plumber. He likes to fix leaks.
Any chance this can be fixed by a DIYer or is the rack toast?
http://forums.corvetteforum.com/show....php?t=2039399
It's less that $200 and a few hours of work. Nothing difficult. I replaced mine with just a rebuilt one from Autozone and have had absolutely no issues.
I'm sure you can just about go anywhere and get the same "quality" of a rebuilt rack.
If it's leaking from there, the internal seal is history. Replace the rack.
