wheel tire choice
Old Jul 15, 2008 | 06:45 AM
jtoombs's Avatar
jtoombs
Default wheel tire choice
hey guys ive spent the last 15-20 mins searching the forums and found some good stuff but i just need a very straight forward or even a 'rude' answer to this ?
can i put 17 X 9.5 wheels with 275/40-45 tires on the front and 17 X 11 315/35 tires on the rear of my stock 89 with no mods or hassles in the future
Old Jul 15, 2008 | 08:03 AM
RWDsmoke's Avatar
RWDsmoke
That's the size (275/40 x17 315/35 x17) I have on my 86 without any problems.
Old Jul 15, 2008 | 09:54 AM
Square's Avatar
Square
I also have an 86' with that tire setup.
The 84-87's have a different wheel offset, than 88+, so I had to get a wheel specifically for my car. Your 89' has a much wider range of Corvette wheels that will simply bolt right on.
Old Jul 15, 2008 | 09:58 AM
jrjr's Avatar
jrjr
Just food for thought, if you run the same size front and rear you can then rotate them front to rear for better wear
Old Jul 15, 2008 | 10:00 AM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
I have that wheel/tire setup on my 93. It looks great, but I have had chronic OC problems with my set up. Just make sure that you make your purchase from a trusted vendor....
Or better yet, buy from the classified section on this board. My story has been documented on this board... you could do a search for the details....
Old Jul 15, 2008 | 10:25 AM
my83432's Avatar
my83432
What the difference between the offsets? I have wheel s from an 88 on my 85 they look fine and don't have spacers. The wheels were on the car when I got it so what had to be done to make them fit?
Old Jul 15, 2008 | 03:25 PM
racebum's Avatar
racebum
i have the split combo on my 90 & it has no clearance issues. your only problem will be tire choices. the 315 has a very limited number of choices. the nitto 555 or 555r are the most popular in my area. high HP cars use the R and stockish bolt on cars the 555, and or people who need a few miles & some rain from a tire
Old Jul 15, 2008 | 05:27 PM
jtoombs's Avatar
jtoombs
ok thanks alot guys thats what i needed to know and it will prolly be the 555's since my car is my DD
Old Jul 17, 2008 | 04:03 PM
Car Guy 88's Avatar
Car Guy 88
I have 275-40ZR17 tires with 9.5 inch rims on the front and back of my 88, stock so front should be fine, and I think 315's will fit on the back, but they'll stick out a bit and as others have mentioned you can no longer rotate them like you could if you had the same size all the way around.
I think the offsets are different on 84-87 cars than and on 88-96 cars.
To wheel tire choice
