valve coer 5/8' hose
Old Dec 27, 2001 | 09:56 PM
Dennis McDougle's Avatar
Dennis McDougle
Default valve coer 5/8' hose
Any of you that might have installed after market valve cover for dress-up
i hope can answer this. What did you use to replace the plastic fitting that the 5/8" hose is connected to that fits into the top of the left cover just below the fuel injectors? This hose now runs to the intake side of the supercharger, could a reducer be use from 5/8 down to 1/2 or 3/8" and not affect anything if this would be the case I could use a pcv cover or even a mopar type breather.
Old Dec 31, 2001 | 03:09 AM
Mo_Bandy's Avatar
Mo_Bandy
Default Re: valve coer 5/8' hose (Dennis McDougle)
Hi Dennis,
I have thought the same thing,when I installed my vortech. i wouldnt think it would drastically effect anything obvioulsy as long as its not plugged~ I have thought of getting some stainless steel pipe to dress it up abit and reduce it down to 1/2 3/8 may be too restrictive..
Mo
[Modified by Mo_Bandy, 1:11 AM 12/31/2001]
