Gar! Code 33 and 36 again!
Old Jul 15, 2008 | 04:07 PM
illinest's Avatar
illinest
Default Gar! Code 33 and 36 again!
On my 86. It's the MAF sensor and MAF sensor burn-off function faults.
This has happened before. I replaced both the burn-off relay and the other one right next to it, don't remember the name of it.
But I have added concern over it happening again only 3-4 years later. Common problem? Advice for tracking down the root cause? Place to get a cheap replacement?
Old Jul 15, 2008 | 04:20 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Have you checked for a cracked wire or bad connector?
Old Jul 15, 2008 | 04:44 PM
DarkBlue88's Avatar
DarkBlue88
From: Charlotte NC, behind someone going 10 under the speed limit
I had this happen, replacing relays didn't fix but a new MAF from NAPA did.
Old Jul 15, 2008 | 05:13 PM
illinest's Avatar
illinest
will check for cracked wire but god forbid if the maf is bad.
of course from what i understand a bad maf should show some kind of symptom other than just a code.
Old Jul 15, 2008 | 08:25 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
I never heard of a cracked wire how would you find that and what does it look like?
Old Jul 16, 2008 | 08:03 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Are you diagnosing with a FSM ??
http://members.shaw.ca/corvette86/Code%2033.pdf
http://members.shaw.ca/corvette86/Code%2036.pdf
To Gar! Code 33 and 36 again!
