O2 Sensor Replacement question
Old Jul 15, 2008 | 08:14 PM
VolMan's Avatar
VolMan
Default O2 Sensor Replacement question
Hello everyone.
I am attempting to replace the O2 sensors on both driver and passenger side of my 95 LT1 coupe (P class engine).
Ok, this is silly, but its my hurdle that I would welcome suggestions on. I cannot access the O2 sensors with a wrench. My 22m open end wrench cannot access either o2 bolt because of the other things around that area of the engine compartment (trying to access it from under the car). The wrench just cant grab it.
I cannot find a 22m flex open end wrench to purchase. That would seem to be what I would need as a tool.
Maybe I am going about this in the wrong way.
Ok, my question. To those who have done the O2 sensor replacement task, how did get them off?
Thanks.
Old Jul 15, 2008 | 08:16 PM
schrade's Avatar
schrade
Never have done that job, but did they both fail?
Old Jul 15, 2008 | 08:29 PM
Scott85's Avatar
Scott85
Get an O2 socket, they're about $10-12 at most auto parts stores, makes the job real easy .
Old Jul 15, 2008 | 08:50 PM
pianoguy's Avatar
pianoguy
Hmmm, mine came out with a 7/8" open-end wrench.
Old Jul 15, 2008 | 09:26 PM
sggyellow95's Avatar
sggyellow95
driver side = 7/8"
pass = o2 socket with a long extension
Old Jul 15, 2008 | 10:58 PM
Klondike's Avatar
Klondike
Just did mine and had to use a couple of different wrenches. I got a couple of them out with a big 7/8 open end wrench and one with a regular O2 socket. The other ( pass. side front if I remember) I couldn't get the O2 socket on because there wasn't enough clearance between the floor and the sensor to get the tool over the top of the sensor or swing a wrench either. I had a 7/8 inch box ratchet with a Z shape that would fit that position but the connector wouldn't fit through the hole in it. Then my Son said, "Dad, that's the old one, just cut the connector off!" (Gets his smarts from Mom ) Cut it, Z shaped 7/8" box ratchet wrench fit right over & got it out. Tightened the new one in with a small channel lock. A lot easier going in than coming out.
Old Jul 15, 2008 | 11:31 PM
sraft's Avatar
sraft
Thanks.
you need this this tool - it make the job a lot easier
http://www.toolsource.com/oxygen-sen...ource=googleo2
Old Jul 16, 2008 | 06:47 PM
Klondike's Avatar
Klondike
OH MAN ! I wish I had seen one of those before I did mine. I almost bought a crowfoot but wasn't sure if it would be long enough. Somebody went to a little trouble to make that thing, it's pretty cool. After the struggle I had, well worth the price too !
Old Jul 17, 2008 | 12:31 AM
VolMan's Avatar
VolMan
Default Update
Thanks guys.
The socket was a much better idea than my previous current path.
The problem now is that the socket does not have enough horizontal length on the arm to clear the exhast pipe.
I will keep looking for others.
Old Jul 17, 2008 | 12:14 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Be sure and use anti-sieze compound (it should come with the new sensors) when you install them. You'll probably have to remove the knock sensor shields, too.
If so, I'd disconnect the battery to avoid creating an electrical short in your starter system.
Finally, the pigtail connectors on the 02 sensor wiring harness tend to get brittle from the exhaust heat. If you break one (easy to do) NAPA sells replacments.
To O2 Sensor Replacement question
