I'm having some problems with the ALDL I made.. the place I got the kit from AKM, isn't answering my e-mails. I can't get it to work. I've tested just about everything I can.
Has anyone else tried using Hyper terminal and connecting to their cable/module and when you type, it echo's back what you type? I can't get mine to do that... :(
I also downloaded a ALDL module tester, and it fails saying that it has timed out.. :(
I was just looking at your picturtes of your PC board in your other post..
Did you double check your capacitors that connect to the MAX232? make sure the polarity is correct.. if these are backwards the Pump function of the 232 will not work correctly.. if at all
Also turn off hardware flow control in Hyper terminal.. That could be cause problems as well
I built the AKM module and it works fine. When doing the assembly, I did have an issue as to the correct placement of the diodes on the board (in the pic that comes with the instructions the clarity is such that it is hard to distinguish between the caps and diodes and which goes where). An E-Mail to Andy brought a VERY QUICK response and clarification.
The unit passed the Hyperlink and ALDL tests on the first try.
Andy runs this business by himself as a sideline and if his real job or a vacation takes him away he could be delayed.
I did have an issue using Craig Moates software and getting it to connect with my car. My laptop uses Windows ME and the software will not connect in the DOS mode. The work around is to boot the machine in the "safe" mode and then everything works fine. Another way to do it is to use a Windows 95 boot disk to start the machine, but this is results an awkward shutdown when you want to turn off the machine. Apparently there are some conflict issues with this software when used with Windows 98 or later operating systems.
Yeah, that's the right schematic. And yes, I have double and triple checked everything on the board and software settings... i'm clueless as to why it's still not working.
The connector I had backwards was the female db25 one.. going to the computer. By putting it on backwards, I reversed pin#20 (Data Terminal Ready) and pin#7 (Signal Ground)... I don't know what (if any) damage this caused.
I'm still registering only 2.5v out from the voltage regulator (i don't think this is right).
Sounds like the culprit is the Voltage reg. Where are you getting the voltage source from? ALDL or Cigarette Lighter? check the voltage on the pins.. 1 and 3.. while having the neagtive on pin 2. Also leave it disconnected from both ends if possible.. if good.. then install on ALDL check again.. then on PC and check again.. maybe you have the VR backwards and smoked it
I"m getting the power from the com port pin#20 (5.0-5.5v).... since the ALDL test program and hyper terminal just require it to be plugged into the computer for testing purposes.
I put the voltage regulator in correctly, and yes I did the tests on leads 1&3 with neg on 2... the Vin is 5.5v (roughly) and the Vout is 2.5v(roughly).... Bill Hardy said that you need to have 7v+ for the regulator to output 5v(based on a datasheet for that regulator in itialian.. of course there couldn't be an english version... :rolleyes:), so i'm thinking maybe my laptop doesn't offer enough power for this thing... not sure..
I'm going to radio shack after dinner to look at some other voltage regulators I could use to try and get the voltage up.
if you are using the Schematic above.. the 7805 needs 12volts to run the 5 volts...
I am confused.. what VR are you using.. is the schematic different from above?
Hmm.. if it requires 12v.. then why do people say that you can hook it up to your laptop and not to your car and it should test ok. :confused: :confused:
I mean, I can see from that schematic above that there is a place to plug in either to a cigarette lighter or the 12v output from the ALDL.. but the module still isn't testing ok like people are saying it should... Am I supposed to have it hooked up to the car for that 12v just to test it as well?
Ok, it's still not working even while hooked up to the car's 12v supply... :( . I'm only getting 4.5v out of the voltage regulator... this is really frustrating :(
Curtis- you are not using the above schematic! That's for an earlier style of ALDL interface. The one you got from Steve is the same as mine according to the pics you posted. Its totally self contained for power. Although... When I hooked up the ALDL connector to the car it blew the 5a fuse in my car power adapter for the laptop! hmmmm.... :confused:
The only thing different about that schematic and the board that we have is the extra diode where the 12v power comes in (that I can tell). Andy affirmed this with me. He's giving me some help through e-mail right now. I'll be calling him later today if I can't get it working.
Yeah, fuses are VERY good ! ;) .. i'm glad that etching on the board made a little fuse for me, otherwise i'd have a toast computer too probably!
No luck on mine, but he said that he would send me a complete tested module board for $15 since I've been trying so hard to get it to work right. So if I eventually get mine to work (i'll probably just throw it away though), then i may offer it to someone for free or something.
