trans fluid foaming
Old Jul 17, 2008 | 08:47 AM
conv90's Avatar
conv90
Default trans fluid foaming
bubbles, bubbles..
overfilled? not!
Why I have foaming and the level when hot is slightly under the hot mark..?
-Beppe-
Old Jul 17, 2008 | 12:14 PM
rons85's Avatar
rons85
One possibility - the Filter/strainer has either come loose or has actually Fallen into the pan (it can't fall very Far..) and is sucking air at the tube connection between the filter and the aluminum housing..
Old Jul 18, 2008 | 07:47 AM
conv90's Avatar
conv90
Can it be a false correct level? ( in real it's overfilled..?)
-Beppe-
Old Jul 18, 2008 | 11:29 AM
Pete K's Avatar
Pete K
-Beppe-
In the summer months, my ciar does it also. I always fill my car to the beginning of the safe zone XXXXXX. This way, in the summer heat, it rises to below the full part of the XXXX.
I would siphon out 1 liter, and see if it improves.
To trans fluid foaming
