L98 intake bolts
Old Jul 18, 2008 | 10:33 AM
bd2626's Avatar
bd2626
Default L98 intake bolts
Question to the folks here, can bolts other than the Torx head bolts be used as a replacement and if so, does anyone know the size off hand. I'm replacing the intake gaskets and the bolts don't look so good!
Den
Old Jul 18, 2008 | 11:29 AM
JonnyAngle's Avatar
JonnyAngle
Personally, I would recommend using torx, but it's up to you. The torx bolts are designed to be more difficult to strip the heads. Go to you local hardware store and they'll get you squared away.
Old Jul 18, 2008 | 11:31 AM
bd2626's Avatar
bd2626
I have ordered a set but I was looking for someone who may have used something different....Thanks!
Old Jul 18, 2008 | 12:03 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Definately be replaced, i've replace with polished hex head and trashed the torx bolts
Old Jul 18, 2008 | 12:10 PM
Demonic85's Avatar
Demonic85
I replaced mine with torx bolts from Jegs, they're stronger than the originals and have a deeper hole so they're not likely to strip out as easily.
Old Jul 18, 2008 | 01:12 PM
bd2626's Avatar
bd2626
Do you have a part number by chance?
Old Jul 20, 2008 | 01:22 PM
eguyett1985's Avatar
eguyett1985
I used ARP black oxide head intake bolts p/n134-2001
Old Jul 20, 2008 | 06:29 PM
MrRenoman's Avatar
MrRenoman
Summit has a set. I used 12 point bolts, 3/8-16. They're pretty cheap, like $12. I'm sure you can find similar sets at most automotive supplies.
Old Jul 21, 2008 | 08:17 AM
dan0617's Avatar
dan0617
ARP's are the best, but I used grade 8 bolts from the hardware store with no problems.
Old Jul 21, 2008 | 02:36 PM
bd2626's Avatar
bd2626
Thanks, got 18 at Fastenal for $5.53, stealership wanted $4.25 each for the Torx head bolts....
To L98 intake bolts
