How do you remove the driver's side door panel?
Old Dec 28, 2001 | 01:04 PM
rhodginz's Avatar
rhodginz
Default How do you remove the driver's side door panel?
I've never attempted anything like this. Is it tough to do? I am comfortable doing minor maintenance items, but don't know about this stuff. Can anyone provide additional information? In addition, the weather stripping needs to be replaced on the door. Can this be done at the same time?
Thanks in advance.
Old Dec 28, 2001 | 04:04 PM
puck's Avatar
puck
Default Re: How do you remove the driver's side door panel? (rhodginz)
What year is this on? I'll assume early C4s. First off, you'll need to remove the screws from the bottom of the door panel [they're actually in the carpet portion of the door panel]. Next, remove the screw above the trunk release button on the door panel. Next, remove the screws holding in the door handle assembly [which also has the windshield washer part]. I believe there are 5 screws on the door handle assembly. Now lift up on the door panel and remove from the door about 6 inches or so and remove the electrical connections. After that is done you should be able to remove the door panel entirely.
If you're talking about late model ones, then i'm clueless :)
-Steve
