gears
Old Jul 20, 2008 | 06:12 PM
jtoombs's Avatar
jtoombs
Default gears
hey guys i have an 89' with the dana 36 performance 3.07 rear end and was wondering where i could buy a set of 3.42-3.45 ring and pinion set or should i just keep the 3.07's? thanks
also do anyone have the borla stinger exhaust on their car maybe with some hooker LT's?
do you like it? have any sound clips? thanks again
Old Jul 20, 2008 | 08:22 PM
biggrizzly's Avatar
biggrizzly
2015 C5 of Year Finalist
I just bought a set of gears from Merle at Exotic Muscle when I ordered my headers. I'm not sure what ratios he has in stock but he can help you out with the selection. I have an LT-1 and went with the 3.56
Old Jul 20, 2008 | 09:05 PM
CJWC4AZ's Avatar
CJWC4AZ
Default Gears, etc.
I have a '90 that had 3:07's. If yours is a daily driver don't change gears get a 2600-2800 TC. Great SOTP improvement. I had Borla Stinger with Hooker LT and the car sounded great all the time. In the cabin it wasn't as much fun. Switched to Corsa. Sorry, no sound clip.
Old Jul 20, 2008 | 09:17 PM
Master__Shake_'s Avatar
Master__Shake_
The L98 doesn't like to rev high at all, so 3.45s would ruin most of it's low-end torque. A 2600 stall converter, or even 3000stall, would put you right into the torque peak and give you one hell of a fun time.
I have 3.07s right now but only the stock 2k stall, and when the L98 was still in it was pretty fun to play with. My powerband is taller now, so not as much fun but that can always be changed. Just remember to make mods that will compliment your curve.
Old Jul 20, 2008 | 09:57 PM
vader86's Avatar
vader86
L98s do not require the rear gear that LT1s like. If you go lower than 3.07, you may get faster to 60, but after that you will be slower. It will also cost you gas mileage on the highway by raising your cruise RPM (similar to driving in 3rd gear now).
You could get the same effect by going to a higher stall TC, without any detriment.
Old Jul 21, 2008 | 04:03 AM
jdraughn's Avatar
jdraughn
I don't mean to hijack this thread, but I have a 1990 and was wondering about gears myself. I don't know whats currently on it but I wanted a bit more speed from 0 to 60, but if possible higher gear on the freeway for better gas mileage.
Changing out the first two gears in the transmission to a lower gear, and the last one to a higher one seems the way to go, but I have no idea if that is even possible.
Anyway, my main question is exactly how does the stall speed of the torque converter effect performance? I thought stall speed was the speed at which the TC locked itself up? I don't see how having a higher speed can make it faster at low rpms, wouldin't it be ineffecient to have the TC spinning and not be locked up?
Old Jul 21, 2008 | 07:21 AM
Weav's Vet's Avatar
Weav's Vet
This should clear that up for you.
http://www.carcraft.com/techarticles...ter/index.html
Old Jul 21, 2008 | 11:22 AM
vader86's Avatar
vader86
http://temp.corvetteforum.net/c4/vader86/A4tranny.html
Old Jul 21, 2008 | 12:00 PM
anesthes's Avatar
anesthes
This is some strange corvette logic that I don't understand. The D36 in the L98's got 2.59:1 ratio for unexplainable reasons. All the L98 fbody cars got better ratios, WS6 being the best at 3.45:1. The WS6 L98 cars all had 700R4's (mandatory) with the same ratios as the corvette.
A Stock L98 C4 at max HP RPM on a 700R4 will go 143mph in drive. How many stock L98's cross the finish line in the 1/4 at 143mph?
-- Joe
Old Jul 21, 2008 | 05:37 PM
jtoombs's Avatar
jtoombs
does anyone have a part number for a good stall i could use?
Old Jul 21, 2008 | 05:56 PM
Weav's Vet's Avatar
Weav's Vet
Contact Pete K here on the forum. He is "The MAN" when it comes to stall converters and a lot of other related questions.
Old Jul 21, 2008 | 11:45 PM
jtoombs's Avatar
jtoombs
thanks guys, i contacted pete and he helped me alot...thanks again
Old Jul 26, 2008 | 06:12 PM
ZD1's Avatar
ZD1
Yep yep
In fact, if you race a L98 2.48 rear you might find yourself owing him/her some money.
Definitely concur with a higher stall converter over gears. With a truck like peak torque at 3K something, a higher stall will allow your motor to stay closer to it peak torqu rating.
though with a 3.07 and today's gas prices, it'll be better to stick with increasing efficiency (heads, headers, n intake) than the gears.
To gears
