Distributor conversion, what will I need.
Old Jul 21, 2008 | 12:16 AM
cwyates4's Avatar
cwyates4
Default Distributor conversion, what will I need.
I still don't know anything concrete about my timing problem yet, but I've been wanting to do this for a while anyways.
I've got a brand new distributor that was setup to go in an '87 L98 trans am. I think these are know as external coil distributors, right? What would I need to convert from what I have now on the '85, to the new model?
Old Jul 21, 2008 | 02:21 AM
pablocruise's Avatar
pablocruise
A conversion harness.
They can be purchased online and they are "plug and play".
-or-
You can make one. That is what I had to do as there were none when I did my small cap distributor conversion many years ago.
You will also need the external coil of course.
Pull the dist at set intervals to monitor gear wear and mesh.
Don't forget to observe the same on the cam's teeth while the dist is out.
Old Jul 21, 2008 | 02:22 AM
pablocruise
Oh BTW, what kinda timing symptoms/problems does the car have?
Old Jul 21, 2008 | 02:38 AM
cwyates4's Avatar
cwyates4
Here's what I've been dealing with:
http://forums.corvetteforum.com/show....php?t=2076515
for an external coil, I suppose the new msd blaster I have on my '87 T/A would work?
Old Jul 21, 2008 | 03:19 AM
rodj's Avatar
rodj
[QUOTE=89 Paul in Cal;1566387174]A conversion harness.
-or-
You can make one./QUOTE]
Email mike@eficonnection.com
He can supply you the HEI to small cap harness (PnP) and the dist coil plug with a long pigtail to the coil.
Good pricing
To Distributor conversion, what will I need.
