Bad ignition module symptoms
Old Sep 26, 2008 | 11:03 AM
  #41
rick lambert's Avatar
rick lambert
We may have covered this, but the pigtail (3-4 wires) coming out of the distributor, 6-8 inches long and very hard to see the next connection (behind engine) did you happen to check it? Hope I made that clear. At one time I happened to get careless (OK, more than once) When I clamped down the dizzy I accidentally clamped that pigtail underneath it. Crimped it...shorted it. Not saying you did that, but it's a section of wireing and connections I'd look at.
Old Sep 26, 2008 | 05:32 PM
  #42
Da Mail Man's Avatar
Da Mail Man
....i never did check the "other" connection behind the engine but, do know that it is almost impossible to see or get at!..should i remove he distributor to get at it?
Old Sep 26, 2008 | 06:06 PM
  #43
rick lambert
I think I just pulled the cap. It is a mother, short piece.When I went to the dealer they sold me one from a caddy, at stealership price...$98.
You may fabricate a hook out of a coat hanger to try fishing it out, but be gentle.
Question for you, not related to this. But didn't you have a fuel pump issue, where it would prime, but didn't have enough volumn, or something like that?
Old Sep 26, 2008 | 06:12 PM
  #44
Da Mail Man
...error deleted
Old Sep 26, 2008 | 06:14 PM
  #45
Da Mail Man
error..deleted...
Old Sep 26, 2008 | 06:20 PM
  #46
Da Mail Man
**let me see if i can get this post right!
***ouch!....is there another connector back there i should be looking at/for?
***see above
***yes, that was a long time ago..it would prime but, would not give me the pressure required. i replaced the fuel pump and all is well..each time the car would not start (as being discussed) i usualy take a fuel pressure gauge and check pressure as a matter of s.o.p. .however, is not the cae in all the non-starts i have been getting...
Old Sep 26, 2008 | 06:47 PM
  #47
rick lambert
No, if you feel comfortable pulling the dist. go for it. then you'll be able to pull the pigtail up. Like I said it's a short piece 4-6 inches long, then plugs into another connection. I think it's important you at least check it for bad connections.
Old Sep 26, 2008 | 06:53 PM
  #48
Da Mail Man
...no sweat on pulling the distributor as i had to do it to change the p/u coil...will give it a try and report back asap!...THANKS!!
Old Sep 26, 2008 | 08:49 PM
  #49
rick lambert
BTW, after you get it out make sure you ohm each wire on the pigtail and clean the connections good.
Good Luck.
Old Sep 27, 2008 | 01:10 PM
  #50
SunCr's Avatar
SunCr
For what it's worth, there's an article in November's Car Craft about HEI's, including basic troubleshooting and (at least unknown to me) that using dielectric - instead of thermal grease - will kill the Module. They found that some Auto Parts stores were passing off dielectric as thermal grease and got what was required at Radio Shack.
Old Sep 27, 2008 | 09:21 PM
  #51
Da Mail Man
...i am aware of that...i usually try not to use the stuff packaged with the modules and have long since purchased and have been all along using the correct compound..it turns out that it seems all the modules i brought back for refund under life warranty have been good and now with the above info posted the other day (200 amp jump start info), seems like there may very well be a bad connection behind and down past the distributor which i will check asap and report back......
Old Sep 28, 2008 | 04:58 PM
  #52
67vetteal's Avatar
67vetteal
Are you saying that Thermal Grease is available at Radio Shack? Thanks, Al W.
Old Oct 10, 2008 | 10:55 AM
  #53
Da Mail Man
...ok, another "no start day" today!...so;
1...removed cap and wires
2...removed rotor
3...removed pigtail from distributor that connects directly to
ignition module (one wire to distributor case is ground) and left
other end connected to harness.
4...the wires are colored as follows (colors may be faded due to
age);
A) purple w/white tracer
B) orange w/black tracer
C) yellow
D) black w/red tracer TO DISTRIBUTOR CASE GROUND
MEASURED VOLTAGES WITH IGNITION ON;
YELLOW + PURPLE W/WHITE TRACER............................= 0.16V
YELLOW + ORANGE W/BLACK TRACER...........................= 0.00V
PURPLE W/WHITE TRACER + ORANGE W/BLACK TRACER....= 0.04V
ORANGE W/BLACK TRACER + BLACK W/RED TRACER (GRND)= 0.00V
YELLOW + BLACK W/RED TRACER =.................................0.20V
while i have not pulled apart the concealed connector as of yet, should there not be AT LEAST 12vdc on any one of these connections powering up the ignition module? also, could or is there an ignition fuse that guards the system? (maybe loose or bad connection at fuse). my manuals are not with me at this time...opinions?...THANKS!
Old Oct 10, 2008 | 11:16 AM
  #54
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Mine made the engine miss lightly when warmed up. One day, it died suddenly, taking my coil out with it.
Engine just quit, resulting in a crank, no-start condition.
Old Oct 10, 2008 | 11:19 AM
  #55
Da Mail Man
coil good..had new one in and went back to old one....same results...cki'ng voltages at connector with pigtail disconected now....suspect a dirty ground on wire as above to case.....however, that doesn't explain why no voltages at pigtail that connects to ignition module.....
Old Oct 10, 2008 | 12:08 PM
  #56
Da Mail Man
UPDATE;
...cleaned all contacts or bent same...sanded ground on distributor as well as gnd. lug....started right up......will monitor.....
Old Oct 13, 2008 | 07:01 PM
  #57
Da Mail Man
......so far so good........
Old Nov 6, 2010 | 11:14 AM
  #58
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Stealth, I would put a capacitor on the power wire on the 3 wire plug that goes to the module in the distributor.
It sounds like you have a voltage spike occasionally when either shutting off the car or turning on the ignition switch, and over time, it finally burns out the power transistor inside the module.
Old Nov 6, 2010 | 08:34 PM
  #59
oldalaskaman's Avatar
oldalaskaman
check dist. terminal board?
