So my dash lights have gone out. The dash still works (the lines in the digital dash still climb with the speedo and what not) and such but the lighting does not work. also my horn has gone out. What should i go through to diagnose?
First check the 3 amp INST fuse with an ohmeter. If ok, then pull the dash cover off the cluster. You will see 4 bright silver lamp covers, remove them and wrap a piece of masking tape that overlaps and use a needle nose pliers on the overlap to pull the lamp STRAIGHT out and check each one with an ohmeter. To replace the lamp, find a piece of tubing that fits over the lamp loosely and insert the lamp STRAIGHT in. If you turn the lamps, you will turn the socket they sit in and you will have to remove the cluster to put the push-turn socket back in place.
The ignition was in run, and the LCDs read out properly, but the backlighting does not work. I have traced down a wire that runs between the INST fuse and the headlight switch. I might just direct run that on a fuseable dedicated powefeed.
well...I checked the bulbs in the cluster just to see, and sure enough the filiment was sitting right there in the bulb, detached from the two posts. After looking long and hard at the wiring diagram, ive come to the conclusion that the reason the INST fuse is not getting any sort of power is because all 4 bulbs are burnt out and if i replace them the thing will work. If this is not the case, then i guess its time for a dedicated power to the dimmer switch.
