AC only blows on low??
Old Jul 22, 2008 | 08:51 AM
pr1mu5's Avatar
pr1mu5
Default AC only blows on low??
Hi All,
AC has always been great in my car until a couple days ago. Now I notice, even if I set the control to blow on '10' it only comes out on the 'low' speed. Still blows ice cold though. Any idea what to check first? Some sort of fan control relay, I've read on the forum? This is on a 1994.
Thanks,
John
Old Jul 22, 2008 | 11:33 AM
pr1mu5's Avatar
pr1mu5
for the lunch crew...
Old Jul 22, 2008 | 12:15 PM
schrade's Avatar
schrade
What does it do without the A/C on, and you max the fan?
Old Jul 22, 2008 | 12:19 PM
dchildress's Avatar
dchildress
With the car idling & A/C on, open the hood and "tap, tap, tap" the fan motor over on the passenger side in the engine compartment to see if it "frees" up the bearings.
Is it making any kind of noise? It shouldn't matter, but try switching between A/C and full heat.
In my Z71, my fan did the same and the fan bearing was making noise. I replaced the fan motor and although the noise was gone, I still had no other speed than 1 (out of 5). I then borrowed my buddy's truck and took his A/C controller out and put it in mine....same thing. I was then told that the $15 control module was probably the problem...and it was. I would start by trying to find the relay module between the fan and the switch.
Old Jul 22, 2008 | 12:50 PM
pr1mu5's Avatar
pr1mu5
Same thing, except warmer air.
Old Jul 22, 2008 | 01:52 PM
schrade's Avatar
schrade
Then we can rule out the compressor being related to the issue, if you're sure the setting that you tried is a setting that does NOT engage the compressor.
Old Jul 22, 2008 | 05:24 PM
pr1mu5's Avatar
pr1mu5
Well I hit the 'Recirculate' button and then went back to normal A/C and the blower magically started blowing on high again.
Whatever...
Old Jul 23, 2008 | 03:03 AM
schrade's Avatar
schrade
I hate intermittents.
Old Jul 23, 2008 | 09:13 AM
rodj's Avatar
rodj
the blower magically started blowing on high again.Whatever...
I would look at a faulty blower module; it controls the fan speed.
Located in the top of the A/c heat box on engine side of firewall .
Has two weatherpak plugs to it.
Old Jul 23, 2008 | 11:22 AM
pcolt94's Avatar
pcolt94
I would at least clean up the contacts on the C68 controller.
Clean the rear connector on the back of the unit. Just use a good contact, safe for plastic cleaner.
Disassemble the unit and clean the pins on the connector which connects both circuit cards together. They oxidize or corrode and cause many of the strange problems. It is also a good time the inspect the solder of the LEDs and buttons. Flickering lights or no response or delayed response are problems with these areas.
You can also measure the 10 steps of the motor control voltage. You can look at the input to it to see if it is correct to. That way you can determine if the module is working or need to look elsewhere.
Old Jul 23, 2008 | 11:28 AM
pr1mu5's Avatar
pr1mu5
I have noticed this, that I'll have to push a button several times (sometimes VERY hard) in order to get the unit to respond.
Any guesstimate on how much work it'll take to get to the back of the unit? Am I basically taking apart the entire dashboard?
Old Jul 23, 2008 | 11:31 AM
grayml's Avatar
grayml
Speaking of A/C problems, my recirculate switch does nothing, would y'all guess a vacuum or module problem? I have the manual climate control in my 94.
Old Jul 23, 2008 | 11:44 AM
pcolt94's Avatar
pcolt94
Hears a short summery.
Got to take off the center trim (and in order) starting with the door for the center storage compartment. Loosen shifter plate, top A/C vent, remove trim plate around radio. Then just 2 screws and the unit pulls right out.
Having the right tools takes 15 minutes, another 1 to 2 hours to service the unit, and half hour to install. I would think the first time thru it will take twice as long.
Be careful and gentle, old plastic breaks real easy.
To AC only blows on low??
