TPI Runners
Old Dec 28, 2001 | 10:30 PM
SLICKMAN's Avatar
SLICKMAN
Default TPI Runners, all the same?
Are all the TIP Plenum & Runners from 1985 to 1991 the same? :(
[Modified by 1991C4, 8:52 PM 1/1/2002]
Old Dec 28, 2001 | 11:11 PM
importeater's Avatar
importeater
Default Re: TPI Runners (1991C4)
fairly sure they are, it's either 88 or 89 then to 91...all the same
Old Dec 28, 2001 | 11:17 PM
SLICKMAN's Avatar
SLICKMAN
Default Re: TPI Runners (importeater)
Thanks!! I'm going to purchase another set to do porting, polishing and a 52 mm TB, then swap everything over.. :D
Old Jan 1, 2002 | 09:52 PM
SLICKMAN's Avatar
SLICKMAN
Just change it, I wanted to know from 1986.. I orginaly put 1988.. Are thay all the same from 88 to 91?
Old Jan 1, 2002 | 10:13 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: TPI Runners, all the same? (1991C4)
They are not the same, '88 has a cold start injector opening whild '89-91 don't.
I believe they're some differences in the TB and/or plenum also.
Check out these parts by year in a catalog to be sure.
Old Jan 1, 2002 | 11:20 PM
Romeo Barrera's Avatar
Romeo Barrera
See my site for pictorial difference between the early and late TPI plenums. The runners are different also in that some were cast and some were extruded aluminum, but that won't make any difference, but the cold start injector hole will.
Old Jan 1, 2002 | 11:48 PM
Aggravated4life's Avatar
Aggravated4life
Default Re: TPI Runners, all the same? (Romeo Barrera)
Accel used to sell a cold start hole block off kit so you could either eliminate the cold start valve or use runners from the 85-88 TPI cars and block it off.
I dont know if they still sell them.I got mine from LPE performance a few years back when I was experimenting with removing the CS valve.It fit the hole perfect.
Or you can cut a tear drop bracket the shape of the edge of that CS area if the runners have a hole and block it off by simply covering the hole,silicone to prevent vacuum leaks, and using the runner bolt to hold it in place.I heard some people stuck a quarter or some coin that fit inside the hole recess,siliconed in place,then custom made a small bracket to cover it.
Old Jan 2, 2002 | 01:41 AM
SLICKMAN's Avatar
SLICKMAN
Default Re: TPI Runners, all the same? (Bill's86Coupe)
Thanks for all the info guys!!! So it sounds like I can purchase a setup from just about any 86-91 TPI and other than the cold start injector, everything should bolt right up. Right? I'm asking this because I'm going to purchase a another TPI setup to do all the MODs on, polishing the outside, new injectors and just change it over and have the old setup as a backup.
To TPI Runners
