Intake Question Opinions Wanted
I should of listed I have a cat back free flowing system new bosch lll's plugs wires cap rotor filters car runs great
If you port the base and siamese the base runners to a depth or 1"-2" you will not lose much low end but will gain noticible top end power, check out the before/after dyno pulls on my site.
I have a similiar setup with megaported siamesed SLP runners which were port matched to the mega ported siamesed plenum -1990 L98.
Some other cheap mods are the Adjust. Fuel pressure reg to 45 psi, Taylor wires, TB bypass, K&N Air filter, tossed frisbee, 180 thermostat, catback magnaflow exhaust and an aftermarket chip.
When I went with the plenum/SLP set up I did not change the intake manifold because the heads don't flow more than about 185 cfm with a stock cam and the stock intake manifold flows better than that -meaning no matter how much air the intake system supplies, the heads are now the flow restriction point.
Anyway - the mega ported SLP system works great. You will definitely lose a little low end torque but it realy wakes the car up from 2000 rpm on up. The stock TPI torque/power wall @ 4500rpm goes away and the car pulls strong to about 5500 rpm.
Some threads have suggested siamesing the intake manifold which
maitains the low end torque and pushes the upper rpm limit. You might want to consider that.
Personnally I thought the megaported system was worth it and if I ever go to a cam and heads for some significant gains I'll decide then what intake I will use.
Good Luck!
