Universal Theft Deterent (UTD) system?????
Old Jul 24, 2008 | 09:30 PM
hz900's Avatar
hz900
Default Universal Theft Deterent (UTD) system?????
'90 auto vert.
Can someone explain exactly how this system works. I have an intermitant no start problem. I first suspected the VATS system, but have bypassed that. I was reading in the electrical service manual and there is a section on the UTD. Could a malfuctioning UTD system cause the car to have a no start issue?
I have power to the starter enable relay, but no power coming from it to the starter side. I checked the wire coming from the CCM which is supposed to ground the relay to work and there was no ground, like when the VATS is not working, however like I said I have bypassed the VATS with an inline resistor, and yes I am sure I did that right.
Old Jul 24, 2008 | 09:47 PM
jfb's Avatar
jfb
Better check your bypass job. I doubt the 90 vettes do this, but later C4's require that the ign key be removed between cranking attempts, so permanently putting a resistor across the VATS module will not work.
The start enable relay must close before the starter solenoid can get 12v and the CCM (VATS module on earlier C4's) must see the correct pellet resistance before it will ground the start enable relay.
Old Jul 24, 2008 | 10:14 PM
hz900's Avatar
hz900
The reason I questioned the UTD is I checked the OHM reading across the fix I did and it was exactly the same as the key. When I installed it the battery cable was disconnected and stilll no start after I installed the resistor and then hooked up the battery cable. Then I grounded the ccm wire to the enable relay and the car turned over verifying the relay was good. Then I took the ground jumper wire away and the car started. What is weird is the only thing I did was jumper the ccm wire to ground to check the relay, nothing else was done between attempts, and the car started the second attempt.
In my manual it says that one wire(gray) coming from the locks is also the "arm" wire. I didn't know what this meant is why I am asking the question. My '86 I was so familiar with did not have this feature so I am unfamiliar with it.
Old Jul 25, 2008 | 10:49 AM
gw962's Avatar
gw962
Your problem sounds similar to mine. You'll need to ground terminal G to A on your ALDL to check CCM codes on your speedo display.
Once your grounded, your display should show 1.1, and any trouble codes will show up. It will also cycle to 4, which is for the ECM.
To see if the CCM is reading your bypass correctly, push the Trip/Odo button and scroll to 1.2. Look in the small display of the odometer and you'll see 01. Use the Eng/Met button and scroll to 06. This shows the VATS Key A/D count. If I recall from an earlier post, your key code is 4, so the display should read between 64 and 70 according to the 90 FSM.
If you have a slightly loose or dirty connection at the CCM, you'll get the dreaded intermittent and the display may show different numbers up to 255. Mine would show anything from 216 to 230.
My initial plan was to remove the interior panels and pull the CCM, but I was able to get a finger into this tight area and move the connections slightly. Bingo, all of a sudden, the display changed from 218 to 154, which is in my key range.
I haven't had any problems for 3 weeks ( yup, I just jinxed myself ), so you might try this.
To Universal Theft Deterent (UTD) system?????
