45psi too much?
Old Jul 25, 2008 | 08:46 PM
all show and more go's Avatar
Default 45psi too much?
well my car has been runnin ruff above 4000 rpm and sputters bad, i changed the fuel pump and am about to change the filter, dont think thats the prob thou, the cars been acting funny since i removed all the emmisions stuff (canister, round black ball, and the valves under the maf sensor) i think all the vacuums might be screwed up (INCLUDING the fuel pressure regulator that has a vacuumto it) please help me, im loosin it!
Old Jul 25, 2008 | 09:49 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If you are seeing 45psi at idle with a stock FPR I'd say you have a vacuum leak. To check it out, remove and plug the vac line to the FPR and check pressure at idle.
Old Jul 25, 2008 | 09:52 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
What is at 45 PSI, fuel pressure ??
Why did you remove the black ball, it's not an emmision device, it's a storage tank for vacuum.
Did you plug all unused vacuum lines after you removed the canister and AIR solenoids ??
Old Jul 25, 2008 | 09:59 PM
well the fpr and the egr are not connected to anything (i know very stupid, but dont know what to do with it) basically the air pump is gutted,got rid of the valves under the maf sensor and everything that goes to them(thanks to the advice of a c4 owner) i also dont have the canister (charcoal) and both of the nipples on the tpi thats supposed to go to the hvac are capped
Old Jul 25, 2008 | 10:09 PM
and im getting a code 54, low fuel pump circuit
Old Jul 25, 2008 | 10:25 PM
maybe someone can find me the entire vac diagram or some pics so i can piece it back together
Old Jul 25, 2008 | 11:51 PM
AGENT 86's Avatar
AGENT 86
2 nipples on plenum= one vac line to FPR, the other to check valve at back of intake . Plug tee at check valve that used to go to vacuum storage tank.
Plug vacuum lines that used to go to canister.
Old Jul 26, 2008 | 07:27 PM
ok, name everything that i can cap off.
Old Jul 26, 2008 | 07:34 PM
cant i just cap the nipple goin to the check valve, if someone could be kind enough to find me a diagram of all the vacuums and direct me to the things i need and the things i can cap off, becouse im missing a lot of stuff, like the air valve and the diverter valve.
Old Jul 26, 2008 | 07:46 PM
will it be easier to just go carberated? i dont mind its stone age parts, im just loookin to get my power back.
Old Jul 26, 2008 | 09:33 PM
bump
Old Jul 27, 2008 | 09:26 AM
MK 82's Avatar
MK 82
Find a good mechanic. A man has to know his limitations.
To 45psi too much?
