I've been trying to find the cause of the my stumble on acceleration for a few weeks. The car doesnt do it all the time, but it does it alot. I've replaced the plugs, wires, coil, cap, rotor, iginition module, fuel pump and all filters. When the car acts up my fuel pressure is solid. I've put a can of injector cleaner in with a new tank of gas. The only code the car had was code 42, which is the EST circuit. I've cleared the code and it hasn't returned in a few days. Any other ideas? I'm trying to get my hands on a laptop to scan and see exactly what is going on.
The engine was rebuilt last year and I had it tuned. Is it possible the car needs to be retuned?
I got it to fit alot better. It actually lines up and holds the distributor properly. I don't have a shim or washer underneath though. I checked the timing a few times after I drove it and the timing hasnt moved.
My bracket looks slightly different from the one in the picture.
You might check and adjust your TPS. I believe the computer uses the signal from the TPS to add a little gas to the mixture when you first hit the gas, like an accelerator pump in a carb.
I forgot to mention that I checked that. It's set to .54volts.
My fuel pressure also sits at 40psi with the vacuum line connected and abouyt 45psi with the disconnected.
Better? ??? Was it upside down? Just loose? What was wrong?
On a '94, and probably other years too, DTC 42 does NOT light SES light - IF your 42 is ICC ground fault, that is...
The EFI temp sensor? It can sporadically send the car rich or lean. Also, since you got a spark code (and you know it wasn't set when you unplugged the jumper to set the timing) you might replace the EST controller. When I bought my vette used it had 3 old EST controllers in the console. I imagine the previous owner had code 42 problems.
90-92 its built into the ECM. Earlier versions are a 1.5x1.5 inch box mounted on the blower motor housing. I don't know if there is any really good way to test it since your problem is sporadic. One way to tell for certain that its working is by tapping the right cylinder head with a small hammer while watching the timing. If it retards, the system, including the EST, is working... at that moment.
They are fairly cheap and easy to replace if you have the early version.
google "esc module" and you can find more info on it.
My car is a 90 so I guess its built into the ECM. So does the whole ECM need to be replaced?
Yes on the fuel pressure. You mentioned your TPS is set at .54 volts, but have you checked it all the way through? the base setting you have is good, but it should increase as throttle opens, I think to 5 volts (double check that) and it should be a smooth increase.
Thanks, I'll check it over all the way through later today.
Well I checked my TPS voltage and it goes up at a steady rate. Starts off a .54v and goes up to 4.6v.
I checked all my fuel injectors and they were all 15.2ohms so they seem good.
Lately my car seems to be doing the stumble all the time. You can even hear it in the exhaust at idle.
The engine was rebuilt and beefed up a bit. Is it possible I need to increase the fuel pressure or timing? Since the distributor was loose, can the teeth be worn or somthing along those lines?
