Oil Change
Old Jul 28, 2008 | 09:15 AM
$300vett's Avatar
$300vett
Default Oil Change
Ok My 85 needs the oil change... Don't know if the previous owner used synthetic-- or reg oil... looking for the best synthetic oil and filter to use..... The motor has been replaced-- it as a 2000 create motor... it has about 10,000 miles
Thanks $300vett
Old Jul 28, 2008 | 02:56 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
I use Mobil 1 and Napa gold (Wix) filters.
Old Jul 29, 2008 | 07:45 AM
$300vett's Avatar
$300vett
Old Jul 29, 2008 | 06:12 PM
93lt1fun's Avatar
93lt1fun
Mobil 1 + K&N or Mobil filter. Mobil 1 was the recommended oil for all '92-'96 C4's with LT1/LT4 when the oil cooler was removed which was used on the L98 and higher engine temp to improve/reduce emissions.
Old Jul 30, 2008 | 07:43 AM
$300vett's Avatar
$300vett
Old Aug 18, 2008 | 11:16 AM
$300vett's Avatar
$300vett
Change the oil and filter-------MPG went from 23 to 27 need all I can get with gas prices------
Old Aug 22, 2008 | 04:59 PM
$300vett's Avatar
$300vett
Ok got about 500 miles on the oil change----- Now I have loud ticking noise comming from the #8 valve cover--- could it be a push rod -- bad valve spring-- or what are the chances that it is the synthic oil I put in it....... used mobil 1 with the K&N oil filter...??? It only hits when you punch into the throttle... in normal driving mode it doesn't do it..........
Old Aug 30, 2008 | 12:54 PM
Jose Antonio Maldona's Avatar
can any one tell me how to turn off the oil change light on my 92 vette?
Old Aug 30, 2008 | 11:27 PM
Spiller's Avatar
Spiller
My 95 manual says
1}turn the key to RUN, but dont start engine.
2} Press ENG MET on the trip monitor. then within 5 seconds, press it
again
3}Within 5 seconds press and hold the GAUGES button on the trip monitor. The Change oil light should flash.
4} Hold the GAUGES button until the CHANGE OIL light stops flashing and goes out. This should take about 5 seconds.
When the light goes out, the monitor is reset.
Old Sep 3, 2008 | 08:05 AM
larry00's Avatar
larry00
I'm lazy but on a 95 does the change oil light accually come on when oil needs changing or at mileage.
My stock 95 has a year on oil change and only 1500 miles.
No sense wasting oil or dough if it doesn't need to be changed.
Old Sep 3, 2008 | 10:40 AM
jrogensk's Avatar
jrogensk
St. Jude Donor '09
Not sure exactly how it works, but when I asked that question on another forum the response was that it uses oil temperature and engine revolutions to decide when the oil is nearly worn out, anywhere between 3,000 and 7,500 miles.
I changed my oil about 1000 miles ago (when I bought the car) so I was going to see how long it takes for the light to come on. I use Mobil1 and I usually go about 6000 miles between changes, at least on my other vehicles. I just bought this car in February so depending on the type of driving I end up doing that may be adjusted.
To Oil Change
