Interior lights question
Old Jul 28, 2008 | 11:06 AM
josephf31's Avatar
josephf31
Default Interior lights question
Getting everything back together (finally!) and noticed yesterday that there are no lights on the radio, heating/ac control head, or the auto trans shift position indicator.
Checked all the fuses in the main box (but not the 2 supplemental boxes) and all the wires, all look OK..
Nothing I can find in the FSM helps (I admit I am not very good at reading wiring diagrams)...any thoughts/ideas?
Thanks again all!
1991 L98 Auto
Joe
Old Jul 28, 2008 | 06:12 PM
jfb's Avatar
jfb
Those lights are powered by the 3 amp inst fuse, check it with an ohmeter. Also, the dimmer control on the headlight switch controls the brightness of those lamps and I would check that you have the dimmer portion of the headlight switch plugged in and fully seated.
Old Jul 29, 2008 | 11:01 AM
josephf31's Avatar
josephf31
Default Is that fuse
in the main box or one of the supplemental ones up in the passenger side of the dash?
Also my instrument lights work fine and the dimmer works so it wouldn't be the headlight switch connector would it?
Thanks!
To Interior lights question
