blower motor
Old Jul 28, 2008 | 01:28 PM
bob31's Avatar
bob31
Default blower motor
Hi
I have a 87 with manual heat/air control. I have checked the other threads here, but I can't find my problem. I have LO-2-3 speed but no hi speed. Found this out this morning sitting at a light.I was going to check out somethings when i get home from reading other threads here.If you can help me pinpoint the problem!
thanks a bunch
Bob
Old Jul 28, 2008 | 03:32 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Blower Relay:
Old Jul 28, 2008 | 03:45 PM
bob31's Avatar
bob31
Originally Posted by Ray Quayle
Blower Relay:
THANKS RAY
Old Jul 28, 2008 | 03:57 PM
bob31's Avatar
bob31
Thanks Ray
Old Jul 28, 2008 | 04:43 PM
bob31's Avatar
bob31
I went out and looked were the relay was and unpluged it from the socket and found the wire connectors in the socket were pushing in,so i held the wires up into the socket and pluged the relay back in BINGO it works now. this was the easiest thing I ever fixed!
THANKS again
Bob
Old Jul 29, 2008 | 02:02 AM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
THANKS again
Bob
Way to go, Bob!
Old Jul 31, 2008 | 10:51 PM
c4_4ya's Avatar
c4_4ya
I have a related problem, I think... my blower usually works only on HI. Sometimes it works on the lower settings until I switch it to HI, then only HI works. Hopefully mine's also as easy to fix...
Old Aug 1, 2008 | 01:46 AM
AdamFromWA's Avatar
AdamFromWA
Navigator
Mine was the same way until I replaced the blower relay and the blower fan switch. Not sure which one it was but it was definitely one of the two (had the console trim off as I was replacing it all so felt it was a good time to pop in a new switch just to be safe).
Old Aug 1, 2008 | 08:59 AM
T J's Avatar
T J
Cruising
Had same problem...was relay..quick trip to local parts store..$22 later I fixed it right in parts store parking lot..easy fix.
To blower motor
