Dynamat or ????
Old Jul 28, 2008 | 03:26 PM
LT4POWR's Avatar
LT4POWR
Default Dynamat or ????
I'm getting ready to gut my interior and put in some kind of sound reducing product. Right now, I'm leaning toward Dynamat Extreme, but I know that there are tons of other products like Dynamat out there. Any feedback would be appreciated. Thanks
Old Jul 28, 2008 | 04:16 PM
LT4POWR's Avatar
LT4POWR
This stuff came up in a couple of searches also...
http://www.raamaudio.com/cgi-bin/index.cgi?p=pr
Old Jul 28, 2008 | 04:18 PM
LT4POWR's Avatar
LT4POWR
http://www.sounddeadenershowdown.com/
Old Jul 28, 2008 | 04:48 PM
JimiHendrix's Avatar
JimiHendrix
Default Awesome Website!!!!
Wish I had seen this before I "home depoted" my car (although I am very satisfied with the result...especially door panels).
The "how to" section is simply the best I've ever seen regarding sound insulation installation. I like the section on how to test for resonance in the door panels. Thanks for the info!!!
Old Jul 28, 2008 | 06:43 PM
cumbercr's Avatar
cumbercr
I used Be-Quiet deadener throughout the inside. Made a big difference.
Old Jul 28, 2008 | 08:32 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Terrific reference...
Old Jul 28, 2008 | 11:37 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
Second Skin Audio best value you can find.
http://www.secondskinaudio.com/
Old Jul 29, 2008 | 12:32 PM
95wht6spd's Avatar
95wht6spd
I used Frost King from Lowe's. I am sure the Dynamat works better, but it is heavier and more costly. It helped cut down on sound and road noise, it was a worthwhile addition. I did the whole inside and the doors.
Old Jul 30, 2008 | 10:38 AM
LT4POWR's Avatar
LT4POWR
Have you used it?
Old Jul 30, 2008 | 01:08 PM
Joe C's Avatar
Joe C
Have you used it?
i've used it - it took 80 sq.ft. to do my 85 - it was a big job, but i'm really kinda **** - a lot of cutting and fitting, trimming, butting seams, etc, but overall, well worth it. i'm on the search for another c4, and i probably go with second skin audio...
Old Aug 31, 2008 | 03:47 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
How much, approximately, to do the doors. Thats all I need, okay the rear carpet too.
Old Aug 31, 2008 | 05:02 AM
Weav's Vet's Avatar
Weav's Vet
I used Dynamat for the rear cargo area and wished I hadn't. Don't get me wrong it works great but it is berri,berri heavy. I was trying to cut down the resonance from the exhaust a little bit. Not a lot of help there but the POS Bose came to life with it. Especially the bass tones.
Old Aug 31, 2008 | 11:27 AM
steve40th's Avatar
steve40th
The doors are the biggest rattlers on my Vette. My engine with LTs/No Cats and Flowmasters is loud regardless. But having the rattles right next to your head sux.
Old Aug 31, 2008 | 12:04 PM
dclafleur's Avatar
dclafleur
I used edead on mine, all the butyl based deadeners work fairly well. I also did a layer of the crazy cowboy precut kit. I also went through and replaced a lot of the interior fasteners at the same time. Really cut down on the rattles and increased the comfort at the same time. On a similar note, the total mass I added to my car with all the deadener I installed was less then fifty pounds. I didn't lose any noticeable amount of time on the track.
Old Aug 31, 2008 | 01:03 PM
BlackHarleyMan's Avatar
BlackHarleyMan
I'm interested to see how you go on this one!..............I'll look to make this move just before next spring on my 96, and I have no idea of what material to use at this point in time.
R/Noland
Old Aug 31, 2008 | 02:29 PM
vetteset8087's Avatar
vetteset8087
I used Dynamat extreme in my 80 and 87 and love it
Old Aug 31, 2008 | 04:44 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Ive always wanted to try this
http://www.quietcoat.com/
To Dynamat or ????
Old Aug 31, 2008 | 06:37 PM
85 500 horse's Avatar
85 500 horse
I had this stuff extensively applied to my car and it WORKS! My door panels were loaded up with this "QuietCar" stuff and the difference, I am told, is night and day. Mind you, my restorer still has my car, but I had him spray this liquid everywhere and he told me that in addition to using Dynamat, he used QuietCar and it makes a substantial and noticeable positive difference. He said the noise the doors now make when closing sounds solid as opposed to what they used to sound like.
You can apply QuietCar via roller or spray it on. I had it sprayed on. The more coats you apply, the better it works.
Old Aug 31, 2008 | 10:52 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Read this thread in the Audio section.
http://forums.corvetteforum.com/show....php?t=2119651
I used Raamat and then Second Skin Over Kill foam in my car. The results were dramatic. My car has true dual exhaust w/ Flowmater 50's, and before the install, you had to speak up to have a conversation in the car, now no problem talking to a passenger or the cell phone. It is so quiet that I am considering replacing my mufflers w/ muffler eliminators so that I can hear the engine again.
Randy
BTW, I have not yet done the doors, that should happen this week.
Old Aug 31, 2008 | 10:57 PM
steve40th's Avatar
steve40th
Are there pre cut systems out there, so you dont have to cut yourself?
And where is the cheapest place to but Dynamat extreme, or Raamat
