Do I have to replace Dual Mass Flywheel
There could be binding, which could be preventing the release bearing from letting the clutch engage. Of course there could be the wrong part issue as well.
Question, do you smell anything like like the clutch disc buring after doing this?
When I replaced my clutch, a piece of advise I got from Jim Jandik was to maroon scotchbrite the new fly wheel and the pressure plate to add a little "scuff" to the surface to aid with break in. Also, it is very, very important that these surfaces are free of grease and chemicals. Just about everything I read suggested frimly to clean all surfaces with a "brake cleaner" type of agent.
Another Q, exactly what to you mean by "giving it gas"? Typicall there is a break in period on new clutches of about 200-300 miles where you do nothing more than normal everyday type driving, before trying any spirited romps on it. This is to allow the disc, pressure plate and flywheel to set and develop a better friction surface. If it gets too much too soon, it can glaze the disc, causing it to lose grip.
I just installed mine and it cost me a little over a grand for the clutch and flywheel.
