90 vette wont accelerate
Old Jul 29, 2008 | 12:25 AM
Epiphany245's Avatar
Epiphany245
4th Gear
Default 90 vette wont accelerate
I am having a problem with my 90 vette. its all stock. The car wont accelerate above 3,000 rpm then it gets all slugish like its not getting enough fuel. I replaced the fuel pump and I still have the problem. The car doe idle roughle. its stable rpms but jumbles occasionally. And when I try giving it alot of gas to drive through it possible i have recently hear what sounds like a bang from the engine, not backfire though. it doesnt bang often, just when I floor it. I can still drive it at low speed and low rpms. any suggestions?
Old Jul 29, 2008 | 12:27 AM
vader86's Avatar
vader86
Possibly clogged cats, but I would check the fuel pressure as well.
Assuming there are no codes and that it does it at all times.
Old Jul 29, 2008 | 12:31 AM
cwyates4's Avatar
cwyates4
hows that fuel filter lookin? any codes? checked plugs recently? Run the car when dark and watch the plug wires for arcing.
Old Jul 29, 2008 | 12:37 AM
Epiphany245
4th Gear
Default 90 vette
Yeah, I changed the fuel filter and spark plugs a month ago.
Epiphany245
4th Gear
Default oh yeah and no codes coming up
Old Jul 29, 2008 | 12:41 AM
Epiphany245
4th Gear
The problem got progressively worse. When it started happening my engine would die when I slowed down, and then it would start up once or twice and drive for 3 more minutes then die again adn then it wouldnt start again. it would crank but not turn over. I also replaced the alternator a month ago
Old Jul 29, 2008 | 01:38 AM
jimmers's Avatar
jimmers
I had a very similiar issue a few weeks ago. I would check the fuel pressure as vader86 said. Your fuel pump might be on its way out.
Old Jul 29, 2008 | 04:17 AM
rodj's Avatar
rodj
Originally Posted by vader86
Possibly clogged cats,.
had exactly the same symptoms
Old Jul 29, 2008 | 10:33 AM
Sweet 90's Avatar
Sweet 90
Have you ohmed your injectors?, My 90 had some of the same symptoms as yours. You said it was all stock so that means you're running the Multech injectors. It might be time to change them
Jim
Old Jul 29, 2008 | 03:45 PM
carson's Avatar
carson
Default do a search for multec injectors
My 90 was stock with 108,000, tuned it up when I got it and later it started to lose power and here is what I did.
Tune-up consisted of; plugs, wires, cap, rotor, ignition coil (they do wear out).
Then it slowly started to run bad and the driver's side cat started to glow red. Replaced injectors and put a Flowmaster Force 2 for the LT1 on (no cats). When I took the cats off, the smaller ones were breaking apart and clogging the main cat.
Brought back power I did not have before. If you have the stock injectors that would be the first thing to replace. Don't be cheap, just replace them, will save you a lot of time.
I'd also stay away from the using an exhaust with an Y-pipe, I think it contributes to resonance.
Old Jul 29, 2008 | 04:06 PM
HOWSER's Avatar
HOWSER
St. Jude Donor '09
Another vote for clogged cats here.
Old Jul 29, 2008 | 10:14 PM
engle1147's Avatar
engle1147
And another vote for bad fuel injectors here.
Not to say that your cats aren't failing or clogged but usually they don't cause the car to stall out unless they are totally stopped up. Blocked cats do cause a lack of power, slowed engine RPM response and the engine may run at a higher temperature....once the exaust is hot the blockage may be more obvious....so keep an eye on that coolant gage.
Good Luck!
Old Jul 30, 2008 | 07:44 AM
KeyWestJack's Avatar
KeyWestJack
Old Jul 31, 2008 | 12:28 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default runs rough
I would take the air filter out of the equasion as well. even a news paper remnant blown onto the air filter housing could cause that
To 90 vette wont accelerate
