Could somebody who has a 92 fsm tell me where the ac clutch relay is located. I have a 90 fsm and It
Says it is under the steering column but I don't know if that changed for 92
Thanx
Jason
According to my 92 FSM, the AC Clutch relay is attached to the rear part of the fenderwell just in front of the battery. It should be the one closest to the outside. It should be the same location and part for either the standard C60 A/C system or the C68 Electronic Climate Control System.
So looking at the relays from the wheelwell, it will be on the far right.
If your car is a 6-speed, the relay just to the left of the AC Clutch Relay is the 1-4 Skip Shift relay and it is the same relay type. You can swap them to test the A/C.
The primary and secondary engine fan relays are also the same relay. These are located on the left side of the rediator shroud near the hood prop rod.
