Should I be hitting my rev limiter?????
Old Dec 30, 2001 | 05:06 PM
GS 163's Avatar
GS 163
Default Should I be hitting my rev limiter?????
I took my car racing a couple weeks ago. With the programming I had I was hitting the rev limiter. I bumped all the shift points back to stock and left the rev lim. at 6000 rpms, when shifting from two to three it sound like it is still hitting it. Only on that shift, all others are fine. Is this normal, I need help, Im confused. :confused:
Old Dec 30, 2001 | 11:05 PM
MY 95's Avatar
MY 95
CI 2-3-4-5-6-8-9 Veteran
St. Jude Donor '05-'06-'07-'08
Default Re: Should I be hitting my rev limiter????? (JPLT1)
are you powershifting???
Old Dec 30, 2001 | 11:27 PM
GS 163's Avatar
GS 163
Default Re: Should I be hitting my rev limiter????? (My 95)
Its an auto, with it in drive, it will sound like it is hitting it just before it shifts into third. Could it be more than just the rev limiter???
Old Dec 31, 2001 | 07:56 AM
MY 95's Avatar
MY 95
Its an auto,
didnt lnow that, as far as I know you shouldnt be hittin the limiter
Old Dec 31, 2001 | 10:08 AM
TennLee's Avatar
TennLee
Cruise-In II Veteran
Cruise-In III Veteran
Does it sound like its hitting the rev limiter before the shift begins, or as the shift begins? If before, you may have a fuel starvation problem, as the automatic shouldn't be letting the car rev to 6K, if after, you may have a torque converter problem, because this trans shouldn't let an engine rev up while upshifting (quite the opposite would be nice).
Good Luck,
Lee
Old Dec 31, 2001 | 12:30 PM
GS 163's Avatar
GS 163
Default Re: Should I be hitting my rev limiter????? (TennLee)
It sounds like it is hitting it before the shift. If it is a fuel problem, what can be done to solve that? :confused:
Old Dec 31, 2001 | 04:48 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
If I have less that 3/8 of a tank of gas mine does that before it shifts bring the gas up to a 1/2 or more it's ok, and I know i'm not hitting the limiter.
Old Dec 31, 2001 | 04:57 PM
ASRoff's Avatar
ASRoff
Default Re: Should I be hitting my rev limiter????? (mackeyred96)
Like Mackey said (when is mackey everwrong? :lol: ) fuel slosh is very bad in these cars I allways makesure I have atleast a 1/2 a tank in the car. If its still doing the same thing try a new fuel filter. If you are modded try 30lb injectors and a 255LPH intank pump. Rember you can never have enough fuel!!! just not enough Oxygen!!!! :lol: :seeya
Old Dec 31, 2001 | 07:22 PM
mackeyred96
Default Re: Should I be hitting my rev limiter????? (ASRoff)
You should talk to my wife:lol:
I have 30 lb injectors but still a stock pump.
Old Jan 1, 2002 | 01:44 AM
GS 163's Avatar
GS 163
Thanks, Ill try that and get back with you. So if I go to the track I would want at least a half tank of fuel to prevent that as well, I guess?
Old Jan 1, 2002 | 12:56 PM
mackeyred96
I alway try to have 1/2 a tank everytime I go to the track. I know it's alot of extra weight but the car does run much better.
Old Jan 4, 2002 | 12:16 AM
ASRoff's Avatar
ASRoff
The extra weight gives Mackey thoes crazy 60ft times :lol: :seeya
Old Jan 5, 2002 | 12:27 PM
GS 163's Avatar
GS 163
Okay, so I took my car out this morning with just over 1/2 tank, still does it. filled it up and still there. So, is this a fuel starvation problem??? What should the fuel pressure be at, I have an AFPR on my car. Or could it possibly be an ignition problem. It has never done this before, until I took it to the track. It had never really been pushed that hard though either for me to notice it. Anyone, please help. :confused: :confused: :confused:
Old Jan 5, 2002 | 10:55 PM
GS 163's Avatar
GS 163
ttt
Anyone???
I was thinking, would the gear change to 3.73's cause it to hit the rev limiter, being that it winds up a lot faster than before?? Also I set all the shift points and rev limiter back to stock this afternoon and it still hits it at the top end of second gear. WTF :confused: :mad
Old Jan 6, 2002 | 03:59 AM
ASRoff's Avatar
ASRoff
ttt
Anyone???
No it shouldent you must have a fuel or spark issues when was the last time you changed the opti-junk? the plugs? or the plugwires?
Old Jan 6, 2002 | 12:37 PM
GS 163's Avatar
GS 163
The opti was changed about a year and half ago and plugs and wires within the last year.
Old Jan 6, 2002 | 11:32 PM
ASRoff's Avatar
ASRoff
Well My only guess is (and this is only a guess) a fuel problem please repost when you figure it out Good luck!!! :cheers: :chevy :seeya
Old Jan 7, 2002 | 12:20 AM
GS 163's Avatar
GS 163
Thanks, ive got my mechanic doing some research as well, Ill let you know when I find something out. :confused:
To Should I be hitting my rev limiter?????
