Ignition
Old Jan 6, 2002 | 11:26 PM
Krafcik's Avatar
Krafcik
Default Ignition
Guys,
I have a stock, aside from exhaust, 1985 coupe. I need to replace my starter i think. Sometimes when I turn my key it grinds, if you will. Is this the start? Furthermore, Are some starters better preformers then other. Please give me suggestions.
Thanks,
CK
Old Jan 7, 2002 | 12:02 AM
AS84's Avatar
AS84
Default Re: Ignition (Krafcik)
Sounds like a bendix problem. Its probably getting hung up in the flywheel or not engaging all the way.
Old Jan 7, 2002 | 01:19 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Default Re: Ignition (AS84)
I'm with AS84 in that I'd check to make sure the starter gear is meshing properly with the flywheel or flexplate before you go buying a new starter.
If you do wind up changing the starter at some point, I'm fairly certain that later model L98's (88+?) used a gear reduction style starter that is lighter. You may want to look into one of these as a replacement option.
To Ignition
